Steering wheel / driveline vibrations - yes? or no?
Old 02-28-24, 03:33 PM
Nickk6
Nickk6's Avatar
Originally Posted by IanG
In the various threads on this topic there have been some great advice and suggestions.
One thing I have never seen mentioned is the calibration of the alignment rack or balancer.
Yes when operating correctly this equipment is great but if is not calibrated, and they should be calibrated regularly, then the results reflect that.
On my previous 4Runner I had an alignment done at a specialized tire & alignment shop, when I drove out of the shop the steering wheel was off centre, brought it right back, they put it on the rack, adjusted again, test drove it, brought it back in ... this happened 4 times. They told me to take it and they would get the alignment rack calibrated and call me when they were ready. A couple weeks later I brought it back in, they aligned it and it drove perfectly. I spoke to the head mechanic and he told me the alightment heads were out of calibration by 1/4".
It would be worth asking when the shop had their equipment calibrated.
The hunter tire balancer can be calibrated on the spot. There is a weight attached to the back of the machine specifically for doing this. It takes 5 minutes to calibrate the balancer, no specialty tools needed.. Alignment rack takes longer, but requires some specialized tools that most shop owners don't buy.
Old 02-28-24, 03:44 PM
IanG
IanG's Avatar
Yup, the question is "has the shop calibrated them recently?"
Old 02-28-24, 08:56 PM
DanTeSlagX
DanTeSlagX's Avatar
I bought a hunter road force balancer new in 2007 They train you for about 5 minutes, its really not that serious of training and there isn't a certification for it. Also its really not hard to let the machine tell you to mark your tire and rim. You then let the air out of the tire, break the bead and spin tire using a tire changer like the TC3700 that has arms specifically for holding the tire in place while the rim spins inside the tire to line up the lines. Reseat tire, fill up air, re run road force to make sure its good and you are done. Also again not sure how a senior guy can balance a tire better than a moron. The machine shows you where the weight goes via lasers and the motor holds the wheel in that spot. You would really have to do something silly to mess it up if you are using a hunter machine. Just my experience from using the machine regularly since I bought it.
*edit* the factory wheels and tires balance great, not sure why you would state they are notoriously difficult to balance? I've actually balanced them and there are no issues I've ever run into.
I’ll ask for the moron next time I’m in for a balance.
The whole forum here, Reddit and other venues are full of people that can’t get their tires balanced. It’s not the wheels. It’s the truck that is very sensitive to how well the wheels are balanced.
the “notoriously difficult” part is from the Toyota tech that did the balance. He met me at the service writer desk because he has owned 3 GX’s and had (correctly) assumed that I was an enthusiast since the truck had a fresh coating of fluid film and I had insisted on the RF balance. That being said he did also tell me that he had removed a comical amount of weights from the wheels.
but the first hand experience is appreciated. I’ve been misinformed about Hunter’s after sales support then.
Old 02-28-24, 09:05 PM
DanTeSlagX
DanTeSlagX's Avatar
Originally Posted by DanTeSlagX
You gotta ask for a hunter road force certified tech. I don’t think non certified can use it anyways but at least by asking you’re telling the service write that you’re the type that pays attention to the details and knows what he is asking for.
Hunter takes their training really seriously.
I do want to add that the GX and its factory wheels are notoriously difficult to balance well.
When I went to the local Toyota dealer to have them do the RF balance, the machine was out of service with no more abrasive tape left on its roller drum. But they had some senior guy do a normal balance instead, and it really smoothed things out a lot. Given the outcome I’d say that a skilled non road force balance is just as good as RF, but I’d still only seek out road force given a choice.
There is still a little shimmy on some roads in comfort setting. That goes away in normal or sport. But then again I’m on AT’s so I think that is responsible for some of it (also getting thr driveline lubed tomorrow so that might help)
the driveline lube, diff flush/fills, and tranny flush/fill definitely made a difference on felt vibrations. Everything is silky smooth and feels like a new truck.
Old 02-29-24, 08:32 AM
thatwasbrilliant
thatwasbrilliant's Avatar
I have it. 2023 new GX. I drive it about once a week and can feel it strongly in the steering wheel and seat. It diminishes with some miles but I've not had a drive over 30 miles on a trip yet to notice but will pay attention to it when I do.
Old 02-29-24, 08:16 PM
Nickk6
Nickk6's Avatar
Just letting everyone know the simplicity so if they have the issue they can ask for the balancer to be calibrated and don't have to worry about the shop giving some bs response not to.
Haha, if you were local to me I would take a look at them for you. It would be interesting to see what the cause is.
DanTeSlagX (03-01-24)
Old 03-01-24, 06:04 AM
DanTeSlagX
DanTeSlagX's Avatar
Thanks @nickk6 I feel our truck is sorted now. But appreciate the thoughts and info.
Nickk6 (03-03-24)
hlippy4
05-22-18 06:32 AM
sryan423
GX - 1st Gen (2003-2009)
10-27-08 10:11 PM
SH212
05-01-08 06:14 PM
mink92890
03-13-06 03:12 PM
manhattan1
Suspension and Brakes
03-14-04 03:37 PM
Quick Reply: Steering wheel / driveline vibrations - yes? or no?
