14mm hex nut appears from nowhere when removing engine under cover
04-28-24, 09:19 AM
6th Gear
04-28-24, 05:25 PM
Check the hood latch or the bracket which supports the center of the grill.
04-28-24, 05:34 PM
6th Gear
Thanks for the advice! Do you have the part number for this hex nut?
04-29-24, 12:51 PM
04-29-24, 01:14 PM
It's a genetic flanged hex nut ... part number ... huh ? ... it could have been dropped from wherever ... maybe an extra ... no need to panic ...
04-29-24, 04:47 PM
6th Gear
Quote:
Originally Posted by
ncblue
just checked, everything looks fine.
04-30-24, 12:56 PM
6th Gear
I hope so...It is a 2022 gx460, and I only changed oil and filter...
04-30-24, 01:25 PM
BTW ... looks like an 8mm Flanged Hex Nut ... the socket size (13 or 14mm) is not the size of the fastener ...
04-30-24, 01:28 PM
6th Gear
04-30-24, 01:29 PM
6th Gear
maybe it is a body nuts?
FirstLexusIS500
IS 500 Threads
04-08-24 08:12 AM
Sin1UZFE
08-06-20 06:33 AM
Boomin
03-19-15 03:13 AM
SC3coupe
07-10-10 02:46 AM
SC3coupe
07-07-10 04:38 PM
