Sagging rear
Sagging rear
Any idea on how to prevent sagging on my 2016 GX 460, I load it up with camping gear and it sags, I put a trailer with 250 pound of tounge weight with a total trailer weight of 3500# and it sags. 135,000 miles.
I keep receiving replies with Gen one issues with air bags, I have a 2016. I really feel this forum is the best way to get real advice. Please help, heading on long trip in a couple weeks.
Not clear ... do you have Air Bag Rear Suspension ?
For the Premium that does not have the Lexus Rear Leveling Feature (Air Bags vs. Springs) ... I have installed Firestone "Coil-Rite" Air Bag Helper Springs ... air bags that install inside the existing rear springs. I use Firestone vs. Air Lift ... the Firestone IMHO has more robust air fittings. I run these at 10psi with no rear load ... and can increase to 35psi to reduce rear-end droop when necessary. Installation is relatively easy ...
Yeah really need to know what your current suspension is. Mine is a 19 Luxury with factory self leveling air bags last month I carried half a ton of lead shot and it never batted an eye. When the time comes on mine I will replace with the same. Even my Polaris Ranger Trail Boss has self leveling air bags on the rear, count me as a fan.
My Tacoma had saggy pants with weight in the bed and or towing so ended up installing Firestone Ride Rite air bags. In the Taco I ran 5 psi empty and 20 with the trailer but only pulled 2.5K pounds. I was the self leveler for the air bags but it isn't that hard to do with a portable inflator using the same batteries as my power tools. I didn't T the lines and had the air fills on either side of the license plates. I also installed Daystar Air Bag cradles so I didn't loose articulation off road. They lasted 9 years with no problems and if you don't have factory air bags would recommend them.
You control the ride by how much air you put in the bags. IIRC they don't recommend zero air and with my Taco empty ran at 5 and you couldn't tell they were even there. With temps ranging from -30 to 80's pressure would vary based on environmental conditions, but you learn after a while what to put in especially for towing. Too much air on washboards could get a little bouncy with too much air but it only takes a minute to drop down and take care of it.
Normally they bolt to the bottom and top the Daystar cradles sit above them so that they are not attached at the top and allow full droop. If they are attached at the top and you spend time off road it will stretch the bags at full droop. Some have had them tear without cradles off roading. Others have said rocks and other objects can get between the cradle and airbag and puncture them. I had mine on for 9 years with cradles and never had an issue with them, and if I were to do it again in the future would go with cradles again. But I spend a lot of time off road and gravel roads with washboards. I don't think you will regret bagging it, instead you will wonder why you didn't do it sooner.
I'm getting the Firestone bags installed on Monday on my MY23 premium +. I tow a flats skiff back and forth about 600 miles one way every other month, and when the rear is loaded down along with a 90lb dog....the rear squats. I do have an ARB air compressor already on my GX so this should help with airing up the bags on the fly.. I'll post up my thoughts and the install next week. I'll add that I did compare the Firestones to AirLift bags and ASE said he uses the Firestones....so that's the direction I went. The bags are about 200$ and the install is 400$. They told me it would take about 3 hours to do. Yota Mafia is doing the work. YotaMafia - Toyota 4x4 Lift Kits, Apparel, Accessories, Gear & More!
ASE (05-29-24)
This is INCORRECT. The correct part you're looking for is this one...Firestone Airide Coil-Rite
No matter the information provided on any Forum ... always order from a retailer that confirms the specific application ... so if there are any issues, you can return without question.
NemesisGX (05-30-24)
Should be this ... Firestone Coil-Rite: 4135 - Rear Kit W237604135 ... assuming you do not have a lift ... meaning stock ride height.
If you stay on road all the time then not as important to have them
Carnevino (05-30-24)
