Traction control light on after alignment check
The title says it all, I took my 2015 GX460 for a reallignment (this was after they did a facing job on the brake discs, polished them, put in my new break pads etc) they also did the reallignment, checked the codes and shut it off for me but it still came on again, what is the reason for this and what should I do?
Do you have the fault codes? if not go to a local auto zone etc and borrow they code reader to get any fault codes, this will help identify what is goin on, with out codes it is just guessing what could be wrong.
can you share teh actual error code/s?
Like below
P1630 Traction control system malfunction
P1633 Throttle actuator control (TAC) system malfunction
P1645 Body control module malfunction
P1646 Transmission control module (TCM) system malfunction
CobraGSF
04-02-15 10:12 PM
