Brake pads for 2021 GX460
Oem ..........
The following 6 users liked this post by ASE:
gmcvey5 (05-18-24),
kgbagent1 (05-22-24),
LatinLS430 (05-18-24),
mike202 (05-18-24),
mketz747 (07-10-24),
and 1 others liked this post.
My experience is you might save like $15 buying aftermarket, just not worth it. You also are more likely to have fitment issues. The last aftermarket set I got, the factory shims wouldn't work on them. Just not worth the headache for such menial savings. I will say though the factory ones dust more than I would like. if you do go aftermarket, Akebono is a good brand.
gmcvey5 (05-18-24)
Super Moderator
When I had recently done brakes I had forgotten some of the brake hardware and picked it up at a nearby Toyota dealer. I just told them I had the same year 4R when ordering the parts since they were the same for the GX
I've used Akebono and Hawk pads. The Hawk pads had less dust, stopped equally as good if not better, and didn't dig into the rotors as much as the Akebonos did. Hawk is now my go to on the GX.
Knowing a bit about what went into brake pads, and more critically, high performance brakes, was of benefit when I used to be an in car driving school instructor with the Porsche and BMW clubs. Many of the rookies would have just installed new high performance pads with drilled Chinese rotors, and after the first 1/2 hour session would be baffled why their rotors were scored beyond trash. There were a couple of reasons...most had installed both new, low quality, yet expensive rotors and pads at the same time---a big no no. One or the other had to have been previously installed, and most of them had no clue about bedding in the pads and rotors. I found that many of the worst cases employed Hawk pads. I personally always used Performance Friction, Carbon Metallic pads. (93 compound)
Based on my experience, the Akebono pads are a product that offers the combination of stopping power and rotor longevity for normal applications. And yes, for severe applications, I would (and have) upgraded to larger two piece rotors and more aggressive pads, recognizing that there will likely be a tradeoff. But, to each his own.
