GX460 Premium Bouncy Ride
Hello everyone,
I want to express my gratitude to all of you for the support I've received from this group since I became a Lexus owner.
I have a Lexus GX460 Premium. Lately, I've been experiencing some issues with the rear suspension of my car. It has been very bouncy, and even small bumps make the ride uncomfortable. This problem occurs intermittently; sometimes it's fine when I start the car in the morning, but then it becomes bouncy and then goes back to normal. I've also noticed that when it gets bouncy, I can't adjust the height using the switch – it becomes unresponsive.
I initially suspected the suspension bags, but upon inspection, everything seemed fine. The shock was replaced just a year ago, so I'm not sure what could be causing the issue.
Does anyone have any ideas about what might be causing this problem?
Not me but
Airbag Man! They make extended length variant as well if you're looking to lift while keeping air shocks
Not me but https://www.youtube.com/watch?v=_pH7-uyJCLE
I'll definitely check the Airbag Man guys to see if they have an OEM replacement. Cheers!
Originally Posted by SamX;[url=tel:11732992
11732992[/url]]I believe it's not a good idea to only lift the rear of the vehicle and leave the front unchanged. This could negatively impact the driving experience, damage the suspension, and limit articulation. It would be better to replace the entire suspension for extended travel, including the struts, arms, sway bars, and so on.
