21' GX460 muffler+res delete bolt-on SS pipe ?
I've recently purchased a 21' GX460 and would like to do the Muffler+res delete. Instead of heading down to my local muffler shop and cutting up my OEM exhaust, i'd like to be able to reverse it the muffler+Res delete. Just in case i decide to sell it in a few years.
Do they sell a bolt-on Muffler bypass ? and Res bypass. or both?
The only thing i can find online is the Carven Dump pipe, but that dumps it under the car.
i'd like to go all the way out the back of the GX with bolt-on bypass stainless pipe, either Muffler delete, res delete or both.
If there is nothing out there, i can go get it cut and possibly buy a used OEM muffler+res later on if i need to resell it, but i'd rather not.
Thanks,
Dave Detherage
Thanks,
Dave Detherage
... 99.99% of Lexus owners would never go there ... unless they also own a 1974 El Camino ...
The following 4 users liked this post by ASE:
Lots of guys will swap out the oem muffler for a flowmaster 50 series. But if you are honestly considering a straight pipe the 50 series likely will be way too tame for you.
BigD026 (05-23-24)
FYI doing ANYTHING to the exhaust, especially removing components, will cause unbearable drone. These GX's are nothing but a huge resonance chamber. It's just not worth it considering the zero performance gains received. I hope you didn't buy this expecting any "sporty" performance.
I never regret my stock exhaust ANYTIME I pull up to or drive by anyone with "Exhaust". Engine Drone is slow, painful and noisy torture for a daily driver IMO - and I hear every single American pickup truck that drives by my house (why does EVERY work-truck need a loud-*** exhaust?
). Not to mention it's like subtracting volume/headroom from your audio system. Did exhaust on my first ride ('87 T4R w/22RE and full LC Engineering/Downey head/cam/headers/exhaust). I'm over it
I used to have 10 screaming fans in my first few DIY PC's as well. Live and learn...
IIRC - Dyno results have shown very poor increases for all that noise and all that $$$. Not like you are adding exhaust, tuning the ECU, remapping and changing transmission behavior in tandem. Even the extremely limited re-programmed ECU's seem "meh" for the $$$ outlay. The transmission shifts and throttle are regulated together for longevity - a Lexus hallmark.
The best sounding SUV's ever are those Benz G-Wagon AMG's with those nasty V8's - they don't drone - but they will open up like crazy. Not really a GX thing...
Toodles - Randy V.
Toodles - Randy V.
BigD026 (05-23-24)
Also, I wasn’t looking performance, just better sound.
thanks
Dave
MrTorgue (05-23-24)
Make no mistake, these 4.6's (and the previous 4.7's) sound ****ing amazing with exhaust work. You just won't be able to stand the drone and the cost vs benefit just isn't there. I wish these didn't drone so bad. I had a magnaflow muffler on mine and it sounded great ... the drone was just too much so I went back to stock. I kept my original factory muffler just in case.
2eXceL (05-26-24)
Gerb
07-18-14 06:59 AM
