Oil Change, ramps and skid plate question
I changed my oil this weekend in my recently purchased 2020 GX460. This was the first time I have changed the oil in an GX460, and I did not use ramps and fighting with the skid plate to get to the oil filter was not easy.
Maybe its a dumb question, but I'm wondering about using ramps in the front and leaving the rear on the ground, will this prevent the oil from completely draining? I realize I could jack up the rear to get it level but I really just need a little extra clearance to drop the skid plate and get to the filter, and I'm wondering if just putting the front on ramps (with jack stands) would work?
I know there are numerous threads on changing the oil, and I have searched through them, but I didn't see anyone address if only use 2 ramps in the front was an issue.
Any advice would be appreciated.
Thanks
Lee
2020 GX460
Thanks
Lee
2020 GX460
Super Moderator
I’ve done many oil changes using ramps just on the front wheels.
Acrad (05-20-24)
If it concerns you get 4 ramps...
Acrad (05-21-24)
If you are just dropping the skid plate on front ramps it is fine. Removing the skid plate and attaching it back is such a pain in the *** because of the hook design and 2 holes it hooks into.
I struggled as well getting the skid plate off on my first oil change as well. If you just remove the 3 bolts holding the plastic piece forward of the skid plate, it then allows the skid plate to fully swing done. Then its totally painless to get the plate on and off because you have room to move it forward and back to clear the hooks. You already remove the 2 bolts and the plastic retainer to let the skid plate swing. Looks like that the plastic piece protects road debris from going up and hitting the radiator and might direct flow.
Take an extra 45 seconds and remove the plastic panel between the bumper and skid plate first, then drop the skid plate. This isn't rocket science.
ejthomp (05-23-24)
... agree with the frustration ... a complete PITA ... the problem ... the "double hook" ... with the second (minor) hook designed to prevent the inadvertent drop of the skid plate when lowered when one is using a lift ... as at the dealership. So, for multiple GX's ... 4-Runners ... FJ Cruiser ... all the same skid plate hook design ... do yourself a favor and completely grind the secondary minor "hook" completely off ... using a Dremel Cutoff Wheel ... or File ... or whatever. This will make removal and re-installation very easy ... even with the plastic panel in place.
BTW ... the FJ Cruiser does not have that plastic panel ... for me, it is not in any way functional ... so can be removed and put in the recycle bin ...
Again it takes less then a minute to remove that plastic panel in front of the skid plate, and when you do the skid comes off and on super easy. I assume that the plastic push fastener was used on that panel as a way to help hold it in place for locating the other hardware....which tells me Lexus intended for it to removed frequently.
I can understand leaving it on if you have an overhead lift. Otherwise, just take it off.
... buy some of these since they easily break ...
... otherwise buy the same "Push Fastener" from Lexus for $3.00-odd per ... crazy ...
mazon.com: GOOACC GRC-32 100 Pcs 100pcs Type Retainer for Lexus Toyota Body, Splash Shield Clips 90467-07201 Replacement, Quality Nylon Push Rivets with Bonus Fastener Remover : Automotive
JWS3
GX - 1st Gen (2003-2009)
11-08-07 01:51 PM
