Wheel Recommendations
Diameter = Same (18 inches) ... Wheel Width = Same (7.5 inches) ... Bolt Pattern = Same (6 x 139.7 mm) ... Hub Bore = Same (106.1 mm) ... with TRD Wheel Offset needing to be compared to the Lexus OEM Wheel Offset to determine any (inboard / outboard) change. Wheel Offset and Tire Size will determine if there will be any rubbing issues. Many posts on this subject in this Forum.
Different Lug Nuts will be required.
GX4602011 (05-28-24)
