Official 2nd Gen GX Modification (DIY) Thread!!
Old 12-02-10 | 06:34 AM
  #166
MickeyS's Avatar
MickeyS
Is there another way to access the backup lights? I'm having difficulty trying to get the bulb. Also, when installing LED's make sure before you assemble the bulb housing that you test the polarity. If it doesn't turn on then you have to reverse the polarity.
Old 12-02-10 | 06:46 AM
  #167
Luke27617's Avatar
Luke27617
What difficulties do you have to get the bulb out? If I remember correctly I got from the bottom of the truck to replace the backup bulbs without any big problems.
Old 12-02-10 | 08:00 PM
  #168
MickeyS's Avatar
MickeyS
It's very tight and can barely reach it! I was able to unplug it but it doesn't reach to far down! I am going to try tomorrow one more time!
Old 12-18-10 | 07:18 PM
  #169
Luke27617's Avatar
Luke27617
A while back I have posted in one of the threads measurements when installing side moldings (from Premium model) you can buy through Sewell. I still get questions for the information, so let me post the picture here where is easier to find. Sorry for lack of drawing abilities.
Attached Thumbnails Official 2nd Gen GX Modification (DIY) Thread!!-side.jpg
Old 12-23-10 | 12:38 PM
  #170
Luke27617's Avatar
Luke27617
Default Valentine 1 with Concealed display wiring
Per request, here it is my Valentine 1 install.
Routing cables is very easy. The side pilar needs to be removed (remove two screws holding the handle). Under the glow compartment there is one screw holding that cover. To remove the center console there are not screws. All you need to do is pop out sides and then pop the center console upwards. Everything else should be self-explanatory by looking at pictures. Please let me know if you have any questions.
Attached Thumbnails Official 2nd Gen GX Modification (DIY) Thread!!-1.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_4292.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_4295.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_4315.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_4319.jpg
Old 01-22-11 | 03:59 PM
  #171
tnguyenmdc's Avatar
tnguyenmdc
Originally Posted by Luke27617
Running Board Lights
Luke,
I've been starting at these running board lights picture that you took. I still can't figure out where they are or how to get to them. Do you crawl underneath the vehicle to get to them? Do you have to remove anything on the running board?
Please help!!!
Thanks,
Old 01-22-11 | 04:31 PM
  #172
gxgonz's Avatar
gxgonz
You have to reach way up in there from the bottom. It is a tough job but can be done. Skinny arms work good but I don't have skinny arms so it was a tight fit.
Old 01-22-11 | 06:38 PM
  #173
Luke27617's Avatar
Luke27617
Originally Posted by tnguyenmdc
Luke,
Please help!!!
Thanks,
It is very easy. Reach out from the top, right over the clear dome which points downward. You will feel a **** with a wire. Just turn the **** like you are trying to replace any other bulb in headlight, fog light, etc... until you are able to pull it out. The wire may feel too short, but will a little tension it will let you turn to the point you can pull it out.
Old 01-22-11 | 06:42 PM
  #174
Luke27617's Avatar
Luke27617
Actualy is not that hard. On each side below there is a plastic plate held by three screws and one with a star pattern. Unscrew the three of them and you will be able rotate the plate so you have plenty of space to put your arm in. I hope this helps. Without unscrewing the plate I am sure it is very difficult to get there.
Old 01-23-11 | 09:45 AM
  #175
tnguyenmdc's Avatar
tnguyenmdc
Are you referring to the backup light or running board light here?
Old 01-23-11 | 10:53 AM
  #176
Luke27617's Avatar
Luke27617
Running board
Old 01-24-11 | 03:56 AM
  #177
gxgonz's Avatar
gxgonz
The passenger side was a little tighter because of the muffler being in the way when you rotate the plastic plate.
We are referring to the reverse lights. The running board lights are the easiest of any light on the car to change.
Old 01-24-11 | 04:39 AM
  #178
Luke27617's Avatar
Luke27617
Actually above in two replies I have responded to running board and the backup light question (post 173 & 174). There were two different inquireies.
Old 04-10-11 | 08:31 AM
  #179
rockydog's Avatar
rockydog
This is a great write up! The only points I'd add:
1. Unscrew the shift ****. Makes it easier to lift the panel.
2. No need to remove "A" pillar/airbag cover. Just use a plastic trim tool (a few bucks at harbor freight) and tuck the V1 cord under the headliner and rubber molding.
3. While you have the panel up, install a second t-tap. Go to Radio shack and get a cigarette socket with cord. Install the second cigarette lighter in the glove box to charge a second device (I have my Ipod in the small compartment with the usb connector, and my phone in the glove box).
Old 05-13-11 | 08:58 PM
  #180
kevinLA's Avatar
kevinLA
Thanks Luke
I got my GX 460 on 4/14/11 and now I have finished the lighs mod. Look Great and I dont think to post pictures b/c your pix very clear and enough
I also did DVD hack. So my wife can also watch movie while the car in motion. The phone and other function work as well on Navigator.
This is the link www.prestigioussociety.com if some one interest to mod.
Quick Reply: Official 2nd Gen GX Modification (DIY) Thread!!
