Official 2nd Gen GX Modification (DIY) Thread!!
#331
Anyone had any luck adding the lower brushed aluminum front "lip" piece that comes on the 2017 Sport editions on a non Sport or previous year model?
Also, has anyone seen an aftermarket replacement for the lower mesh/honeycomb part of the front grill? Would like to figure out a way to have the horizontal lines of the upper portion of the grill extend to the bottom like on the new 570 n
Twelve1 (01-18-17)
#334
Anyone interested in changing your signal to LED. Here is the link of the lights I just changed all 4 on my 16. No hyper flashing, brightest signal ever seen in the market right now. It is plug and play.
#335
https://www.amazon.com/LUYED-Lumens-...rds=luyed+7440
im looking to change the lights in both my cup holders to white LED and the light where you plug your USB in. Anyone done this mod?
Thats a great Mod. I've been reading a lot on upgrading my high beams from yellow to something white. I have a 2014, any solution ?
JuBu (07-07-18)
#341
I cannot seem to find the bulbs any longer. They are Sylvania 5000K units and were about $9-12 each.
Apparently the ones I have are no longer available. I installed the Sylvania bulbs for the running boards and the front dome lights. The others were some non-named bulbs I had purchased many months ago from eBay.
Try the Sylvania bulbs if you can find them, they are GREAT and I have been using them for more than two years without any problems.
213NSX (09-03-18)
#345
Can anyone tell me what's the reason for getting Vleds over Philips or Yorkim or Sylvania? Seems like Yorkim LEDs are a lot cheaper than Philips or Sylvania or Vleds. I was all set to get Philips for $6.50 each when I found the Yorkim for like $1.00 each!
