Official 2nd Gen GX Modification (DIY) Thread!!
Old 06-22-17, 07:03 PM
  #346
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
Personally I've never had a failed VLED or any odd lighting behavior so I've stuck with them. The ones I bought are somewhat designed for outside use as well.
They are also local to me. I can't speak for brands above. The only LEDs I've had that experienced premature failure were from superbrightleds.com.
The running board models I used have 26 LEDs on them.
http://www.vleds.com/shop-bulb-numbe...194-26-ho.html
Old 06-23-17, 05:23 PM
  #347
DallasDave
DallasDave's Avatar
Originally Posted by mattau
Can anyone tell me what's the reason for getting Vleds over Philips or Yorkim or Sylvania? Seems like Yorkim LEDs are a lot cheaper than Philips or Sylvania or Vleds. I was all set to get Philips for $6.50 each when I found the Yorkim for like $1.00 each!
I am not saying it will the case with any inexpensive bulb, but I have had a few eBay units fail on me. They will flicker OR have had diminished light output (due to several of the LEDs burning out). That's never been the case with the Sylvania.
I think if you stay with a "mainstream" bulb you will be fine. Plus the better/more expensive bulbs usually produce more light anyway.
Old 06-24-17, 05:12 AM
  #348
mattau
mattau's Avatar
I am going to get Philips 194 LEDs since they works out to $5.85 ea. and they last 12 yrs. How many do I need? I read 16 but I think I counted 18
4 for the four doors courtesy lights
6 for the front, centre and rear dome lights
4 for the running boards lights
2 for the front side marker lights
2 for the rear side marker lights
Am I correct? Is there a point in changing the front side marker lights if you have DRL and HID?
Philly01 (01-25-19)
Old 07-24-17, 10:11 AM
  #349
Chadmacc
Chadmacc's Avatar
Not really a mod, but has anyone done anything with the lower grill? Not replacing with billet and the like, but adding some chrome rope or anything else??? Just looking for a change to that part. would be cool to dress it up. thanks,
Old 07-24-17, 03:14 PM
  #350
Chadmacc
Chadmacc's Avatar
Default Yellow Fog covers?
What does anyone think about the yellow fog lamp covers?? Easy to do.
Old 07-25-17, 04:10 PM
  #351
tecman
tecman's Avatar
What is the purpose?
Old 07-25-17, 04:39 PM
  #352
Acrad
Super Moderator
Acrad's Avatar
I haven't run yellows in years but it is supposed to be the best in fog & snow conditions.
http://www.lamin-x.com/Fog-Light-Film-Covers-s/1816.htm
"The yellow light output doesn't reflect off of the white conditions"
Chadmacc (07-25-17)
Old 07-25-17, 04:41 PM
  #353
Chadmacc
Chadmacc's Avatar
Two fold in my opine.
1. yellow fog lights provide better viewing in fog and snow due to the contrast of colors.
2. Its something different.
Also, the product is pretty cheap as opposed to other cosmetic changes.
Old 07-25-17, 04:44 PM
  #354
Acrad
Super Moderator
Acrad's Avatar
The Morimoto fog LEDs I just put on had an option for yellow LaminX.
Old 08-20-17, 12:15 PM
  #355
ActionJack
ActionJack's Avatar
Default LED Fog Lights?
I'm looking to swap out my halogen stock fog lights to LED to come closer my HID headlights. Is it just plug and play for a LED H11 led bulb? I tried searching through this thread but I wasn't too successful.
Old 08-20-17, 12:27 PM
  #356
Acrad
Super Moderator
Acrad's Avatar
I'd highly recommend the Morimotos that are basically plug and play. Hardest part if one can consider that is you need to use a voltmeter to determine which connection is + or - and push the electrical connector into correct spot. Really simple and they look great. A housing designed for an LED makes all the difference.
https://www.clublexus.com/forums/gx-...ed-fogs-2.html
Old 08-21-17, 03:48 PM
  #357
rattmobbin
rattmobbin's Avatar
So anyone have the hyper-flash when they swap their turn signals with LED bulbs?
Just did mine today and they're hyper-flashing all over the place. Really don't feel like wiring up load resistors as all the wiring is a total PITA to reach, and I can't seem to find a LED flasher relay for the newer GX, so what the heck are all you guys doing???
Old 08-21-17, 04:08 PM
  #358
tecman
tecman's Avatar
unfortunately I think you need resistors.
https://www.clublexus.com/forums/gx-...nal-bulbs.html
Old 08-21-17, 06:53 PM
  #359
hzhao
hzhao's Avatar
I used those from Amazon (
https://www.amazon.com/gp/product/B071VTS4WS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B071VTS4WS/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
) no hyper flashing for the most of the time. When I had only front one replace, worked perfectly. Since I replace all four of them, it seems once every so often it will hyper flashing. My guess is the load on the circuits may just at the board line of the triggering point. I am going to add two resisters like this from Amazon (
Amazon Amazon
) in the front (since it has more open areas to mount those with affecting other wires as it gets pretty hot.
Old 09-09-17, 07:08 AM
  #360
wulffza
wulffza's Avatar
Default LED interior bulb swap
I did the LED bulb swap for interior dome lights, door courtesy and running board lights yesterday. Used Phillips 194 T10s off Amazon, about $13 a pair, 14 bulbs needed. The before and after is incredible, now to tackle those footwell lights..
(a couple of the thumbnails posted sideways but should be upright when expanded)
Attached Thumbnails Official 2nd Gen GX Modification (DIY) Thread!!-img_9299.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9338.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9304.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9334.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9306.jpg
Official 2nd Gen GX Modification (DIY) Thread!!-img_9335.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9308.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9341.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9343.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9344.jpg
Official 2nd Gen GX Modification (DIY) Thread!!-img_9320.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9324.jpg   Official 2nd Gen GX Modification (DIY) Thread!!-img_9322.jpg
Quick Reply: Official 2nd Gen GX Modification (DIY) Thread!!
