Official 2nd Gen GX Modification (DIY) Thread!!
Old 09-13-19, 12:39 PM
  #421
GB2011GX
GB2011GX's Avatar
I'm looking for that post where someone (Jacket did it 1st I think) added 2nd row USB charger to the rear of his center console. I'm not having any luck finding it. PM me the link if you can find it please!
never mind... found it!
https://www.clublexus.com/forums/gx-...x-460-a-5.html
Old 09-13-19, 05:10 PM
  #422
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
I have a lot of the mod based CL threads linked off of the GXOR Wiki
https://lexusgxor.com/
GB2011GX (09-16-19)
Old 10-06-19, 11:44 AM
  #423
ChrisOK
ChrisOK's Avatar
Old 10-12-19, 09:31 PM
  #424
ObsidianBl
ObsidianBl's Avatar
Originally Posted by ChrisOK
I Need more information
Old 10-13-19, 06:09 AM
  #425
ChrisOK
ChrisOK's Avatar
Do you want full details or just a list of components?
Old 10-13-19, 06:22 PM
  #426
ObsidianBl
ObsidianBl's Avatar
Either or would be fine. I’ve never seen this before and thought it was really unique. Do you have this wired up to switch pros or just a single switch?
Old 10-14-19, 07:51 AM
  #427
ChrisOK
ChrisOK's Avatar
I bought the light from Amazon
Amazon Amazon
Where everything comes from. Removed the center logo piece and removed the L. Sanded everything down with 80 grit paper and filled with body filler.
After some sanding and a few skim coats I primed and painted it and let it cure a few days. After it was cured I used the template with a drill bit and jigsaw to cut out the area to insert the light. Ran a switch into the dash and tapped into the 12 volt for the "cigarette lighter". all 3 front lights are on one switch. I have one extra of the center light if any one is interested. I will post pictures in a few minutes.
The following 2 users liked this post by ChrisOK:
John00 (10-27-19), ObsidianBl (10-14-19)
Old 10-14-19, 09:26 AM
  #428
ChrisOK
ChrisOK's Avatar
Old 10-14-19, 11:33 AM
  #429
ObsidianBl
ObsidianBl's Avatar
I bought the light from Amazon https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Really clean looking install! Thanks for sharing closeups of it.
Did you tap into the cig fuse with an add a fuse or the actual wire going to the cig outlet?
Old 10-14-19, 12:40 PM
  #430
ChrisOK
ChrisOK's Avatar
into the wire and added its own fuse
Old 10-24-19, 10:58 AM
  #431
jameshtx
jameshtx's Avatar
Originally Posted by Chasin
Got my dash cam and V1 radar detector wired up and installed.
Is there a link you guys could share on how to hard wire the V1? Thx
What's the make/model of this dash cam? thx
Chasin (10-24-19)
Old 10-24-19, 12:46 PM
  #432
ObsidianBl
ObsidianBl's Avatar
not the guy who posted but
dashcam should be the viofo A119 or A119S
hardwire info
https://www.clublexus.com/forums/gx-...d-install.html
https://www.clublexus.com/forums/gx-...-question.html
https://www.clublexus.com/forums/gx-...unt-power.html
You’ll need the radar mount. It can be found on amazon and the invisicord to tap into your mirror. Or you can make your own. It’s just telephone wire and 2 plugs soldered.
The following 2 users liked this post by ObsidianBl:
Chasin (10-24-19), jameshtx (10-25-19)
Old 10-25-19, 11:24 AM
  #433
jameshtx
jameshtx's Avatar
@ObsidianBl Thanks for the info
The following 2 users liked this post by jameshtx:
ObsidianBl (10-25-19), Philly01 (10-25-19)
Old 11-11-19, 11:51 AM
  #434
Acrad
Super Moderator
Acrad's Avatar
Philly01 (11-11-19)
Old 11-11-19, 04:06 PM
  #435
Acrad
Super Moderator
Acrad's Avatar
The following 2 users liked this post by Acrad:
GXHutto (06-07-24), Philly01 (11-11-19)
Quick Reply: Official 2nd Gen GX Modification (DIY) Thread!!
