Hood flexing up and down at highway speeds
I know most are concerned about drifting GX which personally is not a big issues and I am sure the issue will be fixed soon by quick software update.
I have noticed something in my GX which is more annoying for me as I have to look at it while driving. At highway speeds the hood in the middle from windshield side is flexing up and down (60+ miles/hr).
Did anyone noticed that as well. Wondering if I have an issue with my hood or Lexus uses thin metal for the hood and everyone has the same issue.
Thanks for the feedback.
Try opening and closing your hood again; when I was picking up my car at the dealer, I opened the hood and closed it, but the sales rep walked over and said it's not closed tight yet. I asked how can you tell and he showed me that the middle will flex if you push down on it; if the hood is shut tight the flexing won't happen. He admitted that the metal for the hood seems to be thinner and softer - probably to save weight - but the flexing shouldn't be a problem if it's shut tight. If you still experience flexing after opening/closing the hood a few times bring it to the dealer, they might have to adjust the mechanism a little. Hope this helps!!
It's really tricky; I thought a traditional "slam it down hard baby " type of hood closing would do the trick, but no. I've only opened and closed the hood once, so I can't really tell you how it's done, but try not to slam it hard, and make sure the hood is aligned properly by looking at the left and right gaps to make certain that they're somewhat equal.
Yeah, I felt like an idiot when the sales rep had to instruct me on how to close a hood at the dealership with other reps/customers looking at me!
You will know if your hood is closed correctly and the gaskets are sealing correctly if there is a uniform 'reveal' of black rubber along the front and side seams. Run your finger along the seams ... if you feel or see a bulge or a gap, open the hood, find and fix the problem and you will be fine.
Regards,
SaniDel
P.S. It wasn't all that long ago that hoods were not only 'ungasketed' but also that they relied on just two rubber bumpers to set their clearance. The GX 460 has more weatherstripping for the hood than some cars have for their doors! ;-)
I think all GX460 have the hood issue. I have just went to a dealership and every GX's hood flexes easily. Using my scientific method just slap your hood in the middle with your hand. The whole thing flexes (vibrates). I bet if you drive any of them at 80 miles an hour the hood would be flexing or vibrating from middle section toward windshield.
Let me know if you see this in yours when you take it on the highway next time.
i think all gx460 have the hood issue. I have just went to a dealership and every gx's hood flexes easily. Using my scientific method just slap your hood in the middle with your hand. The whole thing flexes (vibrates). I bet if you drive any of them at 80 miles an hour the hood would be flexing or vibrating from middle section toward windshield.
