Fog Lights as DRL
#31
Could someone please post links to the module and switch posted above.
Thanks
Koz
#32
#33
Look forward to your write up. One suggestions that may be worth trying before cutting the fog light wires.
The module will shut down fog lights when lights come on. I am sure you still want to use fog lights at night. Instead of cutting the fog lights wire, how about using wire tap. That way fogs will come on when you turn on the car even if the lights are off and will stay on when you drive at night with lights on. An always on option.
Just thinking now, maybe just by taping + wire on parking light and connecting it + wire on fogs would let fogs run with switching to parking lights on.
Anyway, look forward to your update. Please do a write up with locations and color of wires you tapped in to.
~ Cap
#34
Cap,
Looking at your install. Did you taped wires in the engine compartment and then routed wires inside the cabin to install the on/off switch. Or you found all the cables around fuse box under the steering wheel? Fog light fuse is under the steering wheel fuse box, so I am trying to figure out if there is a way to do a nice clean install by taping wires there.
#36
Super Moderator
Not exactly what you were looking for but this old thread might steer you in the right direction
https://www.clublexus.com/forums/gx-...ts-as-drl.html
LS430Lexus
02-24-17 02:09 PM
MAK1885942
ES - 5th Gen (2007-2012)
10-21-16 11:10 AM
