Couple Questions
Couple Questions
I had a 250h as a loaner when I had my IS in for warranty work. The 250h had a cool tire pressure monitor system that indicated the actual pressure in all four wheels. My IS only indicates one of the four is low on pressure. What kind of system is in the 460? Also is the intelligent high beams part of a package (option) or is it standard?
Koz
Koz
Koz
Koz
1st question not sure of...would like to know though
Koz
Koz
On board indicator wouldn't help you anyway. It measures the pressure while the vehicle is moving so you wouldn't get the new correct reading until you start moving again. You have to use the pressure gauge anyway. Also used an electric air pump I got at Walmart for $10 which work out great.
joako
07-04-05 01:24 PM
