Upgrading tires to something larger?
Old 10-27-10, 01:54 PM
Capirato
Capirato's Avatar
Default Tire Comparison
Originally Posted by JsGX460
After about 100 miles of driving, I'm showing about 17-17.1 mpg. more city than highway. I feel like I would have gotten about 17.8-18 with the previous tires. So yes, there is an impact.
Tire Comparison.
~ Cap
Attached Thumbnails Upgrading tires to something larger?-tire-comparison.gif
Capirato is offline
Old 10-27-10, 08:32 PM
T4Fun
T4Fun's Avatar
you put a 285 tire on our 7.5" wide rim . NOT cool pal. Sidewall failure and high probability of accident driving around with this set up. What tire store let you put this on? I dont even want to explain. This was discussed to death on the 4runner forum regarding the narrow 20 inch rims on the limited (7 inches wide mind you) and people putting 275 profile tires on them. I highly advise people here reading this to NOT do this. 285 tires need wider rims, and you cant use the gx stock rims for this.
T4Fun is offline
Old 10-28-10, 07:25 AM
JsGX460
JsGX460's Avatar
Yep. I did. I'd do it again too.
Just as many folks on the 4Runner forum already have.
This has been done with pickup trucks and SUVs alike in my area for a long, long time. I won't go into all the reasons and justifications.
JsGX460 is offline
Old 10-28-10, 10:21 AM
19psi
19psi's Avatar
tires look great on there; its' what they should have come with to begin with, along with a slightly lower axle ratio to make up for the height. then you'd have your gas mileage back.
don't worry about the width of tire and wheel. i'm sure you know, a lot of off road guys use a narrower wheel to help keep the tire on it if htey can't run beadlocks.
for that matter, a lot of diesel guys run 315's on their stock 6.5" wide wheels. I haven't heard of a problem yet.
19psi is offline
Old 12-12-10, 03:08 PM
Alaska
Alaska's Avatar
I also plan on using a taller tire (1.2" more than stock in overall diameter). How does the stock transmission gearing ratio behave with your new tires?
Aside from mpg impacts, do you see any noticeable difference in engine RPM behavior? Also, how about braking feel and performance?
Alaska is offline
LexBrett
10-10-15 11:48 AM
kapdori
Wheels and Tires Classifieds
02-20-05 08:00 PM
Quick Reply: Upgrading tires to something larger?
