New GX 460
I have had the GX for three weeks and I love it as much as the first day. I can not find a fault. It does show dirt but I really like the color. Look forward to summer and fall and going to the passes. I have not done that in awhile.
Hal
GX 2011
LS 2004
Hal
GX 2011
LS 2004
I had a similar situation (but my 2010 RX450H was bought) After test driving the GX460 I traded my RX for GX and never regretted it.
i would expect the rx to drive better than the gx on road. off road, gx would prevail. If you want prowess, then no doubt the gx wins hands down.
Imho, the GX looks better thant the LX even
Hal
I test drove a GX 460 yesterday and can't stop thinking about it. I'm driving a 2006 LX and want to get into something that gets better milage. Can you tell me what you are averaging under normal conditions?
Thanks
Rick
Thanks
Rick
I'm getting 15mpg in strictly city driving, meaning no highways/freeways, just stop-and-go traffic.
Thanks guys. I was hoping the MPG numbers were a little higher. I would like to justify my desire to get one just because it drove so well. I'll keep looking for a 7 seater with decent economy that doesn't act like a morphed mini van.
Hal:
I'm unfamiliar with "summer gas" ... is that something specific to your state?
Although for modern vehicles it is a thing of the past, elevation used to be a significant factor for efficiency, knocking and other engine performance matters. There has been some discussion in this forum of how the GX 460 is affected by elevation:
https://www.clublexus.com/forums/sea...archid=6298957
Regards,
SaniDel
Regards,
SaniDel
Hal:
Regards,
SaniDel
Regards,
SaniDel
Just did a google search to answer your question about summer and winter blend fuel...
What’s the difference between summer-blend gasoline and winter-blend gasoline?
Does it affect my car’s performance?
Cars using summer-blend gasoline spew fewer harmful emissions and get slightly better fuel economy than those using winter-blend gas during the summer months.
The difference between conventional summer- and winter-blend gasoline has to do with the Reid Vapor Pressure of the fuel. RVP relates to the volatility of a gasoline. The more volatile a gasoline, the more likely it will evaporate as the temperatures rises; evaporated gasoline contributes to unhealthy ozone and smog levels. Summer gasoline has a low RVP and is less likely to evaporate when compared to the high RVP winter grade. The Environmental Protection Agency says conventional summer-blend gasoline contains 1.7 percent more energy than winter-blend gas, which contributes to the summer blend’s slightly better gas mileage.
The Energy Information Administration says the switch between the two fuels happens twice a year, once in the fall (winter blend) and again in the spring (summer blend). Summer-blend gasoline is typically more expensive to produce than the winter blend, and it won’t affect vehicle performance or the durability of the engine and fuel system, according to the EPA.
In many large cities as well as California and New England, the EPA requires the use of reformulated summer- and winter-blend gasolines. These RFGs contain oxygenates that lower RVP and other toxic chemicals even further than conventional gasoline.
