Last edit by: IB Advertising
Browse all: Interior
- How to Adjust Door Lock Settings
Step by step instructions for do-it-yourself repairs
Door Lock Q&A
#61
OP is referring that GX rear passage doors can not be unlocked by pulling the inside handle twice when it is in locked status, like newer Lexus (or other manufacturing cars now days). It is a separate function and mechanism other than "child lock feature which you can not open the door from inside completely.
#62
Super Moderator
#63
I have it set to one touch/push to unlock all doors and turned off shift or motion lock as I don't want to wear out the locking mechanism lol.
#64
I have a 2021 GX and it seems like it's impossible to lock the doors while the rear glass is open. When I tried this the doors didn't lock and the open door alarm alerted. Is there a workaround for this or am I missing a setting somewhere? I'd like to be able to lock the doors but leave the rear glass open when I leave my dog in the back in his crate.
Thanks for any advice.
#65
You can try to use a screw driver and press down on the locking latch see if it helps. Just to make sure to unlock before closing the glass.
#66
Super Moderator
You could try this too. It is compatible with the 460
https://radrubberdesign.com/product/...ss-stabilizer/
#67
Fantastic! That looks like a perfect solution. Thanks!
#68
Super Moderator
#69
Is there a way to have the doors look automatically after I park the vehicle and walk away? I just got a 2023 gx 460.
I've tried googling and non of the door lock settings seemed to work.
Thank you.
Thank you.
#70
Super Moderator
#72
#73
The buttons on the trunk do not respond when I press them. I can lock and unlock the trunk with the fob or the other lock and lock buttons. What can I check to fix it?
#74
Just started today.I normally leave it unlocked when in my garage so I can just walk out and put stuff in or out. Now every time I walk away it locks. Of course I can get in with the key fob but it’s annoying. I was unloading some stuff I took to Goodwill and every time I went to get another box it locked itself and I had to unlock it again. Gotta be a setting somewhere. Any help appreciated!
2013 GX Premium
2013 GX Premium
Boomin (11-09-23)
