Glass breakage sensor does not work.
Old 05-30-11, 12:24 PM
jaleels
jaleels's Avatar
Default Glass breakage sensor does not work.
Many of you will be surprised that the glass breakage sensor that you purchased extra for does not work. I tried to test the response of the gbs and nothing. The sensitivity has to be turned up on the gbs unit.
jaleels is offline
Old 05-30-11, 02:18 PM
NC244GLT
NC244GLT's Avatar
How do you turn it up?
NC244GLT is offline
Old 05-31-11, 07:14 AM
jaleels
jaleels's Avatar
The unit for the gbs is located behind the passanger dashboard. The Sewell website has the pdf instructions to install the gbs and is shows where the gbs unit is located and how to access it.
jaleels is offline
srumman
HS 250h Model (2010-2012)
14
03-08-18 08:42 AM
Ather
04-16-14 06:40 PM
Bobjann
11-21-12 12:17 PM
SeanGTS
04-07-10 12:38 PM
Quick Reply: Glass breakage sensor does not work.
