Buzzing noise from left rear wheel
Old 03-18-24, 08:16 PM
shmelvin1
shmelvin1's Avatar
No air suspension....
Old 03-19-24, 04:18 AM
jonshonda
jonshonda's Avatar
Originally Posted by mike202
Is this a GX460 Luxury? If so I suspect it is the air compressor for the rear air suspension. It is running to maintain the set height even with the vehicle off. Might be a sign that the rear air springs are leaking.
Pretty sure the compressor won't kick on after that amount of time to level the vehicle. Maybe within 1 min or so of shut down, but not much past that.
The buzzing sound is most likely your evap. Consider yourself lucky to have experienced such an amazing event occur!
Old 03-19-24, 11:14 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,646 Likes on 2,388 Posts
I've only heard that evap sound a couple times in my years of ownership
https://www.clublexus.com/forums/gx-...ear-wheel.html
It's normal
Old 03-19-24, 01:21 PM
shmelvin1
shmelvin1's Avatar
A unicorn of a noise it is, this is my 6th Lexus 2 RX's, 1 LX, 1 GX, 1 LS, and a Prado.
I feel so privileged to have heard it, sort of a David Attenborough moment.
The following 3 users liked this post by shmelvin1:
Acrad (03-19-24), shawngt2 (03-19-24), tntcandy (03-19-24)
Old 03-20-24, 04:50 PM
BurbanMud
BurbanMud's Avatar
Default On mine, a clicking instead of a buzzing or humming.
The sound I heard on mine was a fast clicking noise - click, click, click, click, click, click.
Happened in the same place as described in this thread: left rear wheel well. I'm guessing the GX (2015 Premium) had been off a couple of hours. I couldn't isolate the sound source. I started the GX, backed it out of the garage and pulled back in. The sound had stopped.
What do you think: Is my clicking sound likely caused by the same thing described in this thread or is it a different mystery?
Old 03-20-24, 05:06 PM
shmelvin1
shmelvin1's Avatar
definitely a "Buzz" not a click
Old 03-20-24, 07:00 PM
John00
John00's Avatar
i get the same sound, every day it seems. theres a small box on the drivers side of the spare. comes from there
Old 03-20-24, 07:21 PM
shawngt2
shawngt2's Avatar
Confident it's the EVAP system. I heard it in my '23 GX and it did worry me but quickly found the answer in the threads. Never heard it again. It's Unicorn level to hear it.
Old 03-25-24, 12:31 PM
KDCarey
3rd Gear
KDCarey's Avatar
This excerpt from the owners manual was posted earlier (a few years ago), but I am reposting here as it is in a different location in the 2023 GX Onwers Manual. My vehicle is a GX Premium WITHOUT the air suspension. So the noise (at least on my vehicle) is not related to any air suspension parts. On page 8 of the 2023 owners manual it states
Noise from under vehicle after turning off the engine: Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction
The following 2 users liked this post by KDCarey:
Acrad (03-25-24), skeener (03-28-24)
hotsaw11
09-27-16 04:00 PM
jkelly1809
11-18-15 07:50 AM
Pinnow
10-05-13 07:23 PM
katg
03-30-11 05:24 PM
teddykrol
SC- 1st Gen (1992-2000)
10-07-01 11:21 AM
Quick Reply: Buzzing noise from left rear wheel
