Water Leaks - Interior
#151
Super Moderator
You probably would need to take the lower dash off to remove that ECU
Will your OBD plug show up in the next few days?
#152
Super Moderator
The adapter will come with link to OBD Link application
I’ve had good luck using that one
Links to download here
https://www.clublexus.com/forums/gx-...k-vehicle-diag
#154
New scanner came in, it's the Body ECU as y'all said it was. Thank you.
Question: The model on the unit in the car is 89221-60180, but I'm only finding part number 89221-60480 for sale. Are the two interchangeable? I've never had a part number come up with nothing on a google search.
#155
Super Moderator
Here is a used one on eBay
https://www.ebay.com/p/13043038383
Seeing a reference that is for a 2019
https://www.ebay.com/p/4050831263
Unfortunately, might need to go with a new one if used one doesn’t show up
https://www.oemvehicleparts.com/oem-...ule-892206a150
#156
Thank you for the eBay link. I had been searching with the dash and that one didn't come up.
#157
Super Moderator
The picture on that eBay link shows 480 so you may want to confirm with vendor first.
#158
BUT I just noticed that the
I don't know what to order now!
sigh
#159
Super Moderator
If not finding any definitive used “180” units you may be forced to purchase a new one. I would reach out to the eBay vendor to see if it is really a “180” or as the graphic shows a “480”. The latter of which you don’t want.
This is the new PN for 10-13 models
89220-6A150
https://parts.lexus.com/p/63379794/89220-6A150.html
You could also put out a used parts search here:
https://www.car-part.com
89220-6A150
#161
Super Moderator
Since 150 is currently listed as known working by Lexus parts I’d look for that one first. The others are probably revisions that are compatible but I can’t say for sure either. I haven’t had to look up BCM info before as failures have not been reported to my recollection.
#162
Super Moderator
Reach out to these yards directly with your 180 part as well
https://www.clublexus.com/forums/gx-...led-parts.html
#163
Super Moderator
Search through list here and contact these yards with Multiplex in description.. make sure 2010-2013
There are few in these pages
https://www.car-part.com/cgi-bin/sea...ey=&userPage=1
#164
Check with parts dept / service at a Lexus dealership? They service these vehicles and should have an access to the answers to your questions.
#165
I have a leak in the exact same area. Were you able to definitely determine the cause of the leak?
