Water Leaks - Interior
#181
best practice is dont rely on doubt or lack of, use tests and checks to eliminate doubt. clogged tubes are not a function of miles driven. realize that many many warranty claims are for issues that were present on day 1 but werent noticed until later. claims such as for pinched tubes from factory.
#182
IanG (09-18-23)
#183
After taking the truck through a car wash there was some water on the passenger side floor board drove for a few minutes and them the trac, check engine, and 4LO light was flashing. Truck went into limp mode and wont go over 25 mph. Pulled all harness connectors that were wet and dried them off. Could this be an ecm issue or secondary air pump?
Update: Scanned for codes and it pulled, P0121, P0123, P0418, and P2121.
Most are for the throttle pedal position. Cleared the codes and the P0121 came back. Truck is running rough and CEL and 4Lo light still flashing.
