Water Leaks - Interior
#61
Yes, sir! The car runs perfectly great! The only thing is sometimes the battery dies and we have to jump it. They have some of the wires i guess not connected right now because they just put a brand new battery and alternator in it. This way it won't suck the power and die on me? I'm not sure? I just need to get it somewhat fixed and get rid of it!
Mbooth (12-11-19)
#64
Are the drains clogged? You can use thick weedeater line to clear the drains out, which is what I did when I serviced my sunroof. If you feed it down from the top you'll see it pop out behind the front tires if there are no obstructions.
Here is the write-up I did when I cleaned mine out; https://www.clublexus.com/forums/gx-...intenance.html
#65
Super Moderator
#67
Super Moderator
Old thread resurrection but saw someone on GXOR with same issue. In that case it was caused by a damaged shark fin antenna on the rear roof. Damage occurred from a car wash.
#69
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Hello,
Need help/advice badly. I have a 2015 Gx 460 still under warranty, Stopped after a car wash, dealer says I had hail repair done to the roof few months back and they forgot to connect a water drain or something around the moon roof and that led to water damage to electronics! 9000$. Here is what they said --> "recommend to start with replacing harnesses and maybe ecus due to water intrusion may need more parts as disassemble of vehicle." can this really happen?? I am at a loss now. Any help / advice really appreciated.
Thank for your time in advance.
#70
What is actually wrong with your car? What doesn't work exactly?
#72
Oil pressure light is always on when car is on, engine not running. Need to hook up a code reader to see what's going on.
#73
Super Moderator
Disconnected moonroof drains will funnel water directly down the A-Pillars onto the ECUs on affected sides.
Did you see any water on the front floor mats or wet carpets underneath?
#74
#75
Super Moderator
You may want to get a second opinion from an independent shop and explore legal actions against repair shop if confirmed and/or talk with your insurance company about botched repair (if confirmed).
Those are dealer costs for ECUs and no telling how many they planned to replace.
Example: Engine ECU is $1500-$2K by itself... there are too many to quickly list. If they are talking about running new wiring harnesses... the labor charges alone could exceed the hardware costs.
Again just speculation if the problem is as bad as they say it is.
romidhaka (08-11-20)
