GX 460 Roof Rack/Bars
Old 03-15-19, 03:04 PM
  #211
oksir83
oksir83's Avatar
Thanks! I also added some Xpel clear protection film under the fairing trim just to prevent any rubbing. After getting everything dialed in, it really is a great rack. Looks perfect on the GX, IMHO.
Old 03-15-19, 03:07 PM
  #212
msgs350
msgs350's Avatar
Originally Posted by Otherone
I left my rails exposed and not too worried about it. My rack was very close on one of the mounts as well but just used some washers to raise it up slightly. One other thing did was to add was some clear 3M film from Amazon where the rack touches the roof under the front windscreen, it's probably not necessary but only took 5 minutes to put a small strip on and nice to have a little piece of mind if it rubs.
Edit: When I installed, I put all the cross members on when still on the ground, but didn't fully tighten so I had some room to adjust if it wasn't straight when we lifted it on top. It was easier to do it on the ground purely because it was more accessible. Other than that it was a fairly straightforward install.
I love the thing if for looks alone.
Good suggestion on the 3M strip. Did you get the wind strip as well? I thought it would be sufficient in protecting the paint but may have to circle back to copy what you did.
Old 03-15-19, 09:30 PM
  #213
Borgs
Borgs's Avatar
Originally Posted by r2m
Glad to see you figured out the glitch to post your truck. Nice truck Borgs! No CHROME and definitely not an 1980's rock crawling pickup!
I can see how this could cause negative cash flow... But do I guess correctly that your main focus is the GX?
r2m, just talked with Tim today. Pulled the trigger on a Gamiviti rack. I think I have the bought the same rack you did! 7 week turnaround.
Old 03-17-19, 09:21 AM
  #214
r2m
r2m's Avatar
Originally Posted by Borgs
7 week turnaround.
Yea, he's not quick, but it is a very quality product, he's easy to work with and IMHO it think the best looking rack if one wants a more safari looking style.
Also, it is among the lowest profile racks so I can get into more parking garages than with other racks. My rig with suspension, tires and rack is 7'-2" (84").
Old 03-17-19, 12:23 PM
  #215
oksir83
oksir83's Avatar
Here is the film I used. I have some 3M Scotchgaurd as well, but the Xpel felt a bit thicker. I also liked that this was cut to 2.75" wide, which is a perfect width, IMHO. It also seems a bit stickier than 3M, so if you use it, make sure you use lots of soapy water so you can move it in place before squeegeeing the water out.
https://www.amazon.com/gp/product/B003EP52BU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B003EP52BU/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I also just got back from a 500 mile interstate roadtrip w/ the rack and I don;t personally feel it is any louder than stock. Maybe in high crosswinds, you hear it a bit more, but nothing crazy. I'm super happy with the Prinsu.
Old 03-18-19, 04:41 AM
  #216
Borgs
Borgs's Avatar
Also, it is among the lowest profile racks so I can get into more parking garages then with other racks. My rig with suspension, tires and rack is 7'-2" (84").
Agreed on all points, according to my research and your insight. I am sure I will love it.
Old 03-18-19, 12:16 PM
  #217
Otherone
Otherone's Avatar
I used the weather strip too, but for such a small cost and effort I went ahead and did the 3M as well. There is definitely more wind noise with the sunshade open, but not bad.
Old 03-18-19, 12:52 PM
  #218
msgs350
msgs350's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks for the link.
For sure, I would have done the same if I had thought about it.
Old 04-03-19, 10:20 AM
  #219
R3loader
R3loader's Avatar
Default Full length roof racks
I was wondering how many here have full length roof racks and which ones have you decided to go with. I am planning on getting a roof rack and was wondering about experiences you have. Thanks.
Old 04-03-19, 10:43 AM
  #220
oksir83
oksir83's Avatar
I have a Prinsu and I love it. Once I got everything dialed in with the fairing position and trim, it has been extremely quiet with no vibration or anything. I'd buy one again without hesitation. I did make 2 spacers for under the center mounts to sleep better at night, but you could easily bolt it down as-is or use a couple washers. Hard to explain without actually having the rack in front of you. It also didn't hurt that it was in-stock with no 1-2 month wait time like some other manufacturers.
Old 04-03-19, 01:54 PM
  #221
KJ6IRM
KJ6IRM's Avatar
I had a Front Runner Slimline installed on mine. I liked the rack, but recently installed a hard shell roof top tent that took up the entire roof rack space. So this past weekend I've removed the rack and installed Rhino Rack cross bars instead.The main reason I did this was to save weight, I should save about 80-100lbs by swapping them out. There was very little wind noise with the sunroof closed with the Front Runner. I liked the modular system and the amount of accessories that they have as well.
GX460 atop Engineer pass, CO.
GX460 with James Baroud RTT. Alabama Hills, CA
bbqsoup (04-03-19)
Old 04-03-19, 01:58 PM
  #222
R3loader
R3loader's Avatar
I did not realize the roof rack is that heavy. I am going to install sliders soon and that is already 100lbs. I would hate to add 100lbs to the top making it more top heavy.
Old 04-03-19, 02:32 PM
  #223
KJ6IRM
KJ6IRM's Avatar
Sorry, my numbers were a bit off. The front runner roof rack by itself is 71lbs installed (I was using shipped weight for the rack at 80lbs). I also had the quick release mounts and the hard shell support channels that were about 20-30 lbs together. The rhino rack cross bars are about 15-20 lbs. So I'd be saving about 70-85lbs.
Old 04-03-19, 02:39 PM
  #224
oksir83
oksir83's Avatar
FWIW, shipping weight on the Prinsu was 57lbs. I figure actual weight is closer to 50lbs.
Old 04-03-19, 03:17 PM
  #225
R3loader
R3loader's Avatar
good looking trucks. We go skiing once a year and I think having the rack would allow me to put the gears on top to get some interior room for the kids.
Quick Reply: GX 460 Roof Rack/Bars
