Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
#139
I've read over all the replies in this thread, and only Eppieguy (above) states the correct, and easiest way to change the oil & filter. It's no wonder so many find the job frustrating... You're all doing it incorrectly, and using the wrong tool[s] (ChannelLocks). The oil filter removal tool for the GX and most ALL other newer V6 & V8 Toyota models is easily obtainable from either Amazon.com or Ebay for $10 (less than the cost of a large pair of ChannelLocks). With that tool on the end of your 1/2" ratchet, the cap of the oil filter comes right off, and, there's plenty of room to turn the wrench. Now, to elaborate on the location of the oil filter.... It's right under the very front skid plate - the first skid plate behind the front bumper. Remove the four 12mm bolts that hold it up and it actually HINGES down (without falling off) to expose the oil filter which is right behind the front stabilizer bar.
Using the right tools (a ratchet, a 12mm socket, and the oil-filter installation/removal tool), the job can easily be done in 15 or 20 minutes. If you want to make the job even easier, get yourself an oil extractor (vacuum) - which is exactly what the dealer uses!
If I was changing the oil the way everyone was doing it earlier in this thread, I'd also be frustrated, and willing to 'just let the dealers do it.'
And, how much do the dealers charge you for an engine air filter? About 3 times what it would cost if you replace the filter yourself - in less than one minute - without turning a single screw.
Last, save yourself the ridiculous cost of changing the Cabin air filter. That filter is in your glove box! Just take your junk out of the glove box, and the cabin air filter is in clear view in the rear of the glove box, and you can purchase new cabin air filters on line for a fraction of what the dealers want for them.
And, why doesn't Lexus (or any premium car maker) tell you how to do these SIMPLE tasks in their bazillion page owners manuals? It's not because these things are too difficult. Rather, it's because they are TOO EASY, and if you knew how easy they are, then the dealers/stealers couldn't justify what they charge for labor on these tasks.
#141
Clickart: The easiest, least messy, and best way to drain your oil is to use an extractor (oil vacuum). The dealers also extract (vacuum) out the oil when they do it. An oil extractor is inexpensive and can be obtained from Amazon.com, and you can use it on all your vehicles - and just about any engine.
#142
#143
The Pela 650 extractor is a very good one. You can find it on Amazon.com Check out the other oil extractors on Amazon while you are there> You'll really like having and using an extractor to remove your own oil in. I even use my extractor to pull the old oil out of my lawnmower and snowblower engines.
#144
Hi guys, have anyone of you change the engine oil on your GX 460 yourself? I would like to change the oil myself, but i heard someone mentioned that we have to remove the skid plate to get excess to the oil filter? Any help would be awesome thanks
#146
The location of the filter at the front, bottom of the engine adds some extra work and time, but it's still pretty easy. The drain plug has an access panel in the skid plates that makes it easy to remove and drain the oil. To get to the oil filter housing, you have to remove that front steel skid plate (4 bolts and a plastic clip as I recall). It's a replaceable element rather than a screw on filter, but the Toyota element comes with everything you need (element + o ring).
Edit: If you've never changed one of these TOyota housing filters before, it helps immensely to have the special wrench to remove the top of the housing. It plugs into a 3/8" or 1/2" ratchet wrench and you can get one for about $10 from Amazon or your local parts store.
#147
Removing the skid plate will give you plenty of room under, and removing it is really easy. It has 4 bolts and using an electric drill will make your job easier.
#148
When I had my GX, I thought about changing the oil myself (I'm a DIYer for all my other cars).
But my local Toyota dealers were able to change the oil with synthetic 0W20 for $60, so it didn't really make sense for me to do it myself, especially since 0W20 is not a common oil you can find everywhere on the shelf.
Of course, my local Lexus dealer wanted to charge me >$100 for the same oil change.
#149
Thanks guys for all your help, i just looked underneath the truck yesterday, it look kinda busy of the skid plate, but like NLu said, if the toyota charge for $60 to change oil on our truck, why bother to do it yourself, because with the filter element and oils cost almost $50 right?, i will give toyota a call
#150
Hmm.. I have paid Jiffy Lube and Goodyear $120 or so for a 0W20 Synthetic oil change.
The above prices don't sound like "Synthetic" with a filter change (Maybe NLu has a connection)?
TXGSF (10-05-20)
