#Oil and #Filter Changes & Oil Filter #Metal #Retrofit Discussion
Old 04-03-17 | 12:55 PM
  #196
clickart's Avatar
clickart
Originally Posted by pinoyesv6
the aluminum oil filter cartridge will fit exactly, you would just have to swap out the perforated filter support tube from your original filter cartridge.
Anybody done it before or we assuming that it will fix exactly? I will probably do this on my vehicle on the next oil change if it fits exactly. Thanks
Old 04-04-17 | 02:48 PM
  #197
Acrad's Avatar
Acrad
Super Moderator
Great Info!!! I'm gonna do this. If the current plastic one wasn't so banged up on mine I may have run with it a little longer. This metal one looks to last the life of the vehicle. Aside from my powersports equipment this is the first vehicle or Toyota product for that matter in my stable to use these kinds of oil filters. Just used to the old metal all in one units.
Old 04-29-17 | 03:53 PM
  #198
Acrad's Avatar
Acrad
Super Moderator
For the DIY'rs... do you find 8.2 quart oil/filter replacement fairly accurate to get you to the top fill mark on dipstick? Or does residual oil in motor still stick around in any way to put it over the mark?
EDIT: I plant to do an 8.2 qt change and draw down some via the newly installed Fumoto valve if it appears there is an overfill condition.
0.2 quart is about 6.4 fl oz
Octavious (01-23-18)
Old 05-19-17 | 05:48 AM
  #199
Acrad's Avatar
Acrad
Super Moderator
Here are videos of a cap swap. This is for 5.7L but steps are the same for 4.6L.
ayaz99 (05-08-19)
Old 05-19-17 | 01:48 PM
  #200
Acrad's Avatar
Acrad
Super Moderator
Reviewed previously posted threads again.
I bought the replacement cap and then realized I forgot to get this part as it isn't present on my existing plastic cap.
PN:
 15643-31050 15643-31050
In addition make sure you get the oil filters that also include the plastic drain as they include the needed gasket. I ordered three of this kind.... I guess I'll keep the other three I previously purchased as spares.
This if you are going to convert to aluminum cover---->
Versus stock kit---->
Old 05-19-17 | 01:53 PM
  #201
Acrad's Avatar
Acrad
Super Moderator
I'd actually like to get ahold of the Amsoil plastic drain. I'd have to buy a filter though. It is threaded and looks like this.
Not a good pic but this is Amsoil filter for GX. Saw a Youtube of plastic piece... nice...
Old 06-17-17 | 08:50 AM
  #202
Acrad's Avatar
Acrad
Super Moderator
A few other stats:
Dry fill amount is interesting....
Oil filter cap torque
This was probably mentioned already but drain plug torque
Not that I would ever let mine get to this level but appears to be an oil level sensor as well.
Philly01 (04-08-20)
Old 07-14-17 | 04:45 AM
  #203
texas008's Avatar
texas008
Default engine oil change at 5k interval
just performed oil change around 5k after dealer's oil change, using 0w20 fully synthetic
the old black engine oil looks pretty bad,
will probably continue with the 5k OCI.
Old 07-14-17 | 04:58 AM
  #204
PLamarine's Avatar
PLamarine
Ok. Very conservative approach.
Old 07-14-17 | 10:12 AM
  #205
bbqsoup's Avatar
bbqsoup
Yeah I think 5K is very conservative. If I don't do 10k on the GX I probably stick with 7.5K or so. Good compromise. I've been doing 7K+ for most of my cars now.
Old 07-14-17 | 11:07 AM
  #206
NewB2Lexus's Avatar
NewB2Lexus
Without sending it to a lab like Blackstone it is hard to tell what is the condition of the drained oil. Just because it's black it does not mean it's bad. If you put a drop on a piece of paper towel it is easier to guess if it is good or bad.
Also the condition of the oil largely depends on how and under what circumstances the car was driven. Short distances in extreme hot or cold calls for more frequent changes than driving long distances on highways. Our GX is driven infrequently at the moment, sometimes stays in the garage for a week or more so its oil is changed once a year. On my other vehicles driven daily I change it every 12 months or if I hit the 5-6k miles mark whichever comes 1st.
The bottom line is: IMHO changing the oil below the 5 k miles mark is a waste of money unless it's been a year old and the truck was driven daily.
Old 07-14-17 | 12:57 PM
  #207
Acrad's Avatar
Acrad
Super Moderator
I try to change yearly with my Amsoil in all cars. This usually puts me in the 7500-10k mile range.
That being said no idea what oil dealer put in my GX so will change it at 5K miles in probably a month. Oil is still really clean looking at 4K miles.
Old 07-14-17 | 07:44 PM
  #208
DallasDave's Avatar
DallasDave
Just curious, if the service booklet says to change it every 10k/miles (unless extreme conditions) why would you change it sooner? My thought is if it's good enough to warranty by the Manufacturer that should be good enough for me. Not trying to entice a riot, but wouldn't that be like replacing your tires when only half their life has been used (or air filter, etc.)?
Old 07-15-17 | 04:10 AM
  #209
PLamarine's Avatar
PLamarine
I agree. Unless you are putting your GX through some rigorous conditions (towing, dust, severe duty) I would stick with what the manufacturer recommends.
Old 07-15-17 | 07:12 AM
  #210
Acrad's Avatar
Acrad
Super Moderator
Consensus on videos and other forums this should be torqued to 9-10 ft-lb
