Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
Koz
It is free but at 10k miles. Interesting that oil change warning just came up at 5k. Also when I have changed the oil 500 miles back it was completely black. For sure don't wait until 10k. Maybe the oil was black already as it was not synthetic to start with. Check and if it is black, don't wait until 10k.
I don't have the GX yet (It's on special order). I just wanted to know were on the engine it is located (left or right side, front or back, top or bottom). Does anything have to be removed? I do know it uses the cartridge type filter. My previous V8 4Runner had the filter located on the bottom in the front of the engine and a skid plate had to be removed.
Koz
Koz
Thanks for the info on the oil filter location. after I take the freebies from the stealer, i'll be changing my own oil with high grade synthetic/blends for about 25k miles. then i'll switch to Royal Purple.
I actually noticed a slight increase in MPG (almost 2MPG HWY) on my 06 GX-470 after switching to Royal Purple.
(No, I do not work for them ;-) )
Koz
Those who bought their 2010 GX 460 early in the first year of production received this letter. It is not as well written as it could be so I asked the Service Manager at a recent reception at the dealership for new Lexus owners. He explained several details, which the letter does not make clear:
1. The GX 460 is delivered with synthetic motor oil. There is no need to replace the original motor oil with synthetic motor oil.
2. The complimentary 6 month/5,000 mile service will check, but not change the motor oil. In addition, they will rotate the tires, inspect the brakes, etc.
3. The 12 month/10,000 mile service is now complimentary and the motor oil will be changed ... with synthetic motor oil, as well as the oil filter and other service items will be performed.
In summary, your Lexus dealer needs to see your vehicle every 6 months/5,000 miles, they will replace your motor oil less often, i.e., only every other service and the first two services are complimentary. So, for the first 12 months/10,000 miles it will cost you nothing other than two scheduled service visits to keep your GX 460 in warranty. If your Lexus dealer is like ours, you can have them pick up your vehicle and return it when done or use a loaner if you take your vehicle to the dealership, plus your vehicle will be washed and filled with gas.
After these two services, the cost of service is the owner's responsibility so they could be done at any Lexus dealer, another car service company or by the owner. However, for warranty purposes, keep good records ... especially if you do the service yourself. Which begs the question ... if you do your own service, how do you prove that you did the service ... and when?
Be aware that using conventional motor oil or a grade other than SAE 0W-20 could be construed as a warranty violation. More to the point, if several years from now your GX develops a problem while still under warranty, but the dealer claims the motor oil is "the wrong color" ... well, saving a little money on maintenance may have been false economy!
Regards,
SaniDel
Regards,
SaniDel
This letter was included with an Updated Maintenance Manual, which superseded the manual shipped with the vehicle. Lexus may have needed to do this with the earliest GX 460 units, but later units may have come with the updated manual. Note that the letter was dated March 2010 ... presumably, units produced after that date already had the updated manual and no letter was mailed.
It seems that the decision to 'qualify' the GX 460 for synthetic motor oil was made recently ... late enough in the design process so that the earliest unit required this manual update. Presumably, the early design of the GX 460 did not anticipate the use of synthetic motor oil so the manuals and service intervals were established for conventional motor oil.
Regards,
SaniDel
Regards,
SaniDel
Regards,
SaniDel
Regards,
SaniDel
So does our oil filler cap ... SAE 0W-20. The build date on the driver's door is November 2009 and it arrived at our dealership in late-December although our Date of First Use (DoFU) for warranty purposes is February 9, 2010 ... it took us that long to be sure! ;-)
Regards,
SaniDel
Regards,
SaniDel
Regards,
SaniDel
Regards,
SaniDel
Well, I took my GX in for it's first oil change at 5,000 miles. Just bothered the heck out of me to have to wait till 10,000. Serviceman tried to talk me out of it.
I also took it in at 1,000, not knowing that the process had changed.
I feel better now.
I plan to change the oil in the future at about 7,500 mile intervals.
~ Cap
I feel better now.
~ Cap
