Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
Old 03-16-19, 06:03 AM
  #331
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
A few quick links for your '11 since you mentioned documentation was missing.
Owner's manual
Nav manual
Quick Reference
Other years here
Old 03-23-19, 05:08 AM
  #332
Dennismt
Dennismt's Avatar
Default 1st oil change for 2011 GX
I have a 2011 GX approaching 100k. I’m due for my 1st oil change. Right now I’m on the 5k schedule. I’m assuming it’s not synthetic oil. Should I switch to synthetic at this point, which I assume would than put me on a 10k schedule. I have all service records and the rig has had oil changes every 5k from the start. Any thoughts??
Old 03-23-19, 06:27 AM
  #333
oksir83
oksir83's Avatar
I would run synthetic and do every 5k miles. I've never been a fan of 10k intervals, even w/ synthetic.
Old 03-23-19, 07:20 AM
  #334
Jacket
Jacket's Avatar
I switched and one of our Toyota’s to synth at 105,000. I did a short interval on the first run in case the synthetic did some deposit and sludge removal to get it out of the pan. I also did a sea foam treatment, but that’s up to you and I know the opinions vary on it.
Old 03-23-19, 08:46 AM
  #335
winterturb
winterturb's Avatar
I have two LX470's with over 300,000k each and have only run synthetic. Both engines run as smooth as they day they were new and don't burn a drop of oil between changes. I use only OEM filters as well. I am a huge fan of synthetic as over time it pays off.
Old 03-23-19, 09:08 AM
  #336
bbqsoup
bbqsoup's Avatar
I think all 0-20W oil is synthetic. So if previous oil changes used the same weight then you’re good.
Old 03-23-19, 12:15 PM
  #337
NTH
NTH's Avatar
^ Just as bbq stated, 0W20 weight oil is synthetic but there are syn blend in this weight as well. I would continue with full synthetic without worry. Also I would do 5k intervals if most of your driving is city, and 10k intervals if mostly highway cruising. My previous GX470 was on synthetic 10k intervals with 170k miles- smooth and silky as new and no oil consumption between changes.
Old 03-28-19, 01:12 PM
  #338
william489
william489's Avatar
Default 2015 GX 460 Oil Change Parts
I am about to do the first oil change myself for my 2015 GX 460.
I have seen folks talk about 04152-YZZA5 and 04152-YZZA3 for oil filter part, which one is the correct one?
Love my GX, except for tractor-like engine starting sound, it is perfect,.
Thanks a lot!
Old 03-28-19, 01:23 PM
  #339
bbqsoup
bbqsoup's Avatar
Both parts are correct.
04152-YZZA5 - if you replace the plastic cap with a metal one then get this one (at least get one for the first oil change). It comes with 2 gasket and you need the small one for the small drain opening.
04152-YZZA3 - If you're not changing the filter cap then get this one. It only has a large gasket. This is also good if you replace the metal filter cap and use YZZ5 for the first change to install the small gasket. After that you don't need to change the small gasket again, then YZZA3 is fine.
Also pick up a few blue drain plug gaskets too.
https://www.ebay.com/itm/GENUINE-TOY...frcectupt=true
Thanks a lot!
ltsr (03-28-19)
Old 03-28-19, 01:27 PM
  #340
william489
william489's Avatar
Thank you so much Sonny!
Old 03-28-19, 01:51 PM
  #341
ltsr
ltsr's Avatar
You didn't mention if you have the oil filter wrench. Here it is:
Amazon Amazon
Old 03-29-19, 07:15 PM
  #342
rick1987
rick1987's Avatar
I did my first oil change the other day.
Wherever the previous owner went for oil changes really hacked it up.
The skid plate was missing a bolt, and stripped another.
I'm going to have to re tap to a bigger bolt.
Also the stock plastic filter housing was soooo tight I thought it was going to break, or my 14" long 3/8 ratchet was going to break.
I'm an ironworker and tighten/loosen structural bolts all the time. There was over 100 ft pounds on that filter housing.
Changed it out to the metal one. If you do that, swap the metal strainer looking piece from your plastic one.
Old 03-29-19, 07:30 PM
  #343
NTH
NTH's Avatar
Should I replace my plastic one to metal? If so anyone have a part number or source?
Old 04-03-19, 10:17 AM
  #344
ObsidianBl
ObsidianBl's Avatar
Hello,
Here is a screenshot of the parts and part numbers for the oil change. Please let me know if anything needs to be modified.
I plan to get the Fumoto valve, metal housing with cap, and the corresponding filter.
JoshDrivin (08-20-20)
Old 04-03-19, 10:18 AM
  #345
ObsidianBl
ObsidianBl's Avatar
Up to you. I believe a few others have decided to due to the low cost and high reward. For only $20-30 you'll have a housing that should last longer than the vehicle.
Quick Reply: Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
