Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
Old 04-12-19, 10:17 AM
  #361
ObsidianBl
ObsidianBl's Avatar
Originally Posted by Philly01
Hi Acrad35751 - what torque do you use on Fumoto 20 or 30 ft-lb torque on the Fumoto?
Also, which metalic cap is the good one (what is the actual part # for the cap):
https://www.amazon.com/dp/B0075MREHI...iglink20326-20
or
https://www.amazon.com/dp/B008BHP68A..._t1_B0075MREHI
Im not Acrad, but these were the parts.
https://www.clublexus.com/forums/gx-...l#post10482687
Toyota of north Miami had the plug and cap on amazon for $24 (OEM parts) but it looks like it’s out of stock. I ordered from them last week but It’s still in transit.
The following 2 users liked this post by ObsidianBl:
Acrad (04-12-19), Philly01 (04-12-19)
Old 04-12-19, 10:26 AM
  #362
Philly01
Philly01's Avatar
Thank you!!!
Old 04-12-19, 11:58 AM
  #363
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
I torqued my Fumoto like drain plug to 30 ft-lb
Philly01 (04-16-19)
Old 04-23-19, 09:46 PM
  #364
ArmandoGX
ArmandoGX's Avatar
Default Bad reading on dipstick?
Hey guys I just recently did the first oil change on my new to me 2011 GX, i put 8 quarts of oil (manual says 8.2) and noticed that it's actually a little over the full dot on the dipstick? Any idea why that would happen? Will post pics of dipstick tomorrow.
Old 04-24-19, 04:39 AM
  #365
Acrad
Super Moderator
Acrad's Avatar
Certain you are on flat ground checking oil or a incomplete drain from ground not being level? Just checking but vehicle has been run since change so oil filter got it’s share of oil?
Old 04-24-19, 06:51 AM
  #366
ArmandoGX
ArmandoGX's Avatar
Yes checked on flat surface
Old 04-24-19, 11:14 AM
  #367
crisp76
crisp76's Avatar
Drive it around and recheck oil level on a different flat level surface. Make sure to wait about 3 minutes after shutting down the engine to check oil.
Old 04-24-19, 07:17 PM
  #368
ArmandoGX
ArmandoGX's Avatar
Thanks man I'll give it a try. My garage seems to be a flat surface that's where i always check the oil lol. Ill take it out and park it on the street and check it tomorrow. Just seems really weird to me.
Old 05-03-19, 05:09 AM
  #369
Beachy
Beachy's Avatar
Mine always reads over, annoys me but has been pandemic across Toyotas I have owned.
Old 05-07-19, 02:35 PM
  #370
Gxxr
Gxxr's Avatar
My first experience at an oil change on my wife’s GX460 was this past Sunday.
Apparently, the fool idiot who did the last oil change at the Havoline station down the way from us must have used an impact on everything except the drain plug.
When I went to remove the front skid plate bolts, the three at the front from the bumper area were missing completely. One of the front two bolts broke off instantly at the head when I was trying to loosen it with a 3/8 standard ratchet, the other bolt was torqued in so hard and had a rounded off head so bad that my bolt extractor wouldn’t work, so I had to drill the head of the bolt off....
luckily, the rear two bolts weren’t too tight to remove (but were overtightened also) and they didn’t break.
The Plastic oil filter housing was overtorqued (of course) and I was able to get it off with a long 1/2 inch ratchet and a hammer.
I switched to the new OEM Toyota Aluminum oil filter housing and swapped the center tube out between them.
The oil was warm(probably 130 degrees still) and when I pulled the plug out, it jumped straight from my oil drain/hold bucket and over onto the concrete, just past the work blanket I had put down.... sigh.... 0W20 flows like water!!! It was literally like a fountain bouncing from one platform onto the driveway. I knew I had oil dry dust and discolored concrete in my near future.
Everything else was fine, thankfully!
The following 2 users liked this post by Gxxr:
Acrad (05-08-19), Philly01 (01-29-20)
Old 05-07-19, 05:30 PM
  #371
John00
John00's Avatar
i ended up using a saws all to cut off the nuts that were inside the small channel, then welded in new ones.
Old 05-16-19, 07:13 AM
  #372
nuclearn8
nuclearn8's Avatar
may be a dumb question but the oil flow path is down thru the center of the filter and out thru the metal filter then thru the filter element and return to the pan?
Old 05-16-19, 08:15 AM
  #373
nuclearn8
nuclearn8's Avatar
anyone know what the 31050 plug size and thread pitch is?
Old 05-17-19, 08:21 AM
  #374
John00
John00's Avatar
the fumoto for gx460 f103 shows m12 1.25
Acrad (05-17-19)
Old 05-18-19, 07:53 AM
  #375
nuclearn8
nuclearn8's Avatar
Not the oil pan drain plug... I know that is 12X1.25, the aluminum oil filter housing drain is what I'm interested in... also interested in the oil flow path thru the filter element if anyone knows for sure. thank you
John00 (05-19-19)
Quick Reply: Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
