Oil and Filter Changes & Oil Filter Metal Retrofit Discussion
#557
gage reading ~normal = amount of heat energy ~normal
gage reading >>> normal = amount of heat energy > energy transfer capability of the sub-system
the close to constant coolant temp (and in acceptable range) indicates that the energy isn't exceeding the sub-system (including all paths) designed transfer capability. With a pretty much fixed max transfer capability, this indicates whether the amount of energy has exceeded the max transfer threshold or not.
Not the best for quantification, but for indication of trend or threshold passage it works.
#559
I'm with ASE on the thicker side of engine oil.
While a 20 weight might be fine, the most important thing to remember is fuel dilution with the 4.6L engine and why an Oil Analysis be completed to include a GC (Gas chromatography) test to find the amount of fuel present in your oil. A sample with the flashpoint alone will not give an accurate % of fuel present in the sample.
The engine is very easy on oil, but short tripping this vehicle will definitely cause a quick and constant reduction in the oil viscosity if you don't get the oil up to temp to allow the fuel to "burn" out of the oil .
#562
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/381x361/oil_054abeee403b4bb53ad7d771fada460c6f6a68e6.jpg)
#563
They also mention that "15W-50 racing oil may be too thick to flow quickly enough to fill the spaces between the crank journals and main bearings while the engine is running." The oil pump is a constant displacement pump. It will move the same volume of oil at the same RPM regardless of the oil weight. If we come back to reality and talk about normal oil grades, it would simply not be an issue to run a 30 weight oil, especially in a GX that is being worked hard.
#564
All interesting conversation ... but Toyota, who designed this engine, has a sliding recommendation based on AMBIENT temperatures. Easy enough to understand.
#565
I've used this thread to change the oil on my GX and per the recommendation of several people I went ahead and got rhino ramps to do the job; I like them and just saw that they are on sale at advanced auto parts. There is a thread on slickdeals, but in summary, with the coupon code its $30 for a pair, or $60 for 4, I think thats pretty good and a savings of $20 over amazon if you were to buy 4.
nuclearn8 (05-16-21)
#566
My F150 I can just slide under and change the oil.
#567
oh no rhino ramps.
make some solid ramps out of 10 or 12" wide boards. rhino ramps will eventually fatigue. dont wana be under there when they fail
look at the underside and see the stress fractures. they are there.
#568
Yeah, one thing that irritates me with the GX is that I cannot slide under it on my creeper with it sitting on the floor. I have to get it up a few inches to fit. I end up using my Rhino ramps for most jobs underneath and will sometimes lift the rear from the trailer hitch using my floor jack to get it level.
While I was replacing the running board lights to LEDs I noticed that I could slide under the vehicle (w/o the creeper). Unless I need additional clearance to remove shielding parts, I figure I'd give it a shot without lifting.
#569
Is it absolutely necessary to lift the GX to do the oil change? I am getting ready to do the first oil change on mine. I have a pair of rhino ramps that I've used for my sedan (also jack & stands), but am looking for a lazy way out.
#570
I would rather just spend the 30 seconds driving it up on ramps then try to squeeze under. Usually, cutting corners to save time ends up just costing more time and frustration. I can remove the turbos from my F150 Ecoboost from the top, but if I spend the 10 minutes to remove the tires and fender liners I can do it through the wheel wells and its much faster overall.
