#Oil and #Filter Changes & Oil Filter #Metal #Retrofit Discussion
#586
I use the Fumoto's for convenience & time savings. I'm often servicing a lot of gear at the same time like multiple vehicles, powersports equipment and lawn equipment. It does take longer to drain but this hasn't been a big deal while working on the other vehicle.
Nytron (05-27-21)
#587
Yes, I drove it to get the oil warm and the sediment stirred up before dropping the oil, it came gushing out like it was under pressure! The oil was hitting the bottom of the pan and splashing right back out, it wasn't a small mess, it was ridiculous. When half my arm is covered in splashed oil from trying to move the pan to a position where it wouldn't splash, I'm gonna try and find a better way for next time. I've been using this drain pan for years, it's only ever been an issue on my wife's Legacy, the only vehicle I've used a Fumoto valve on previously.
TBH, not actually sure if either of those things would increase or decrease pressure, might depend. Just got my GX a week ago and am about to do an oil change soon...Regarding those two questions I posed above, I'm gonna do the opposite of whatever you did, lol.
Also going to use a shoulder length field dressing glove used for hunting to prevent getting my arm full of oil, lol.
#589
0W20 is thin enough to drain nicely and reasonably completely even when cold IMO.
#590
Did you partially remove your dipstick and oil filler cap before removing the drain plug?
Drain plug was perfectly clean, but you don't know what you'll find in there until you pull the plug, so probably not necessary for next time.
#591
I have about 85K miles in my 2015 GX. We live in CT. I have been using Mobil 0W20 for past oil changes. I plan to switch to Mobil 5W30 (normal type, not high mileage one) going forward for all seasons, would there be any issue for the switch? We have some cold winters here, not too bad though. I care more about engine protection.
Thank you.
Thank you.
#592
Thank you.
Thank you.
mainstream. My winters may drop below freezing for 3-4 weeks, with summer temperatures being 75-95 degrees ... with the latter (more recently) becoming more prevalent.
To your question ... 5w is good for the majority of US winter conditions, and the 30 weight providing improved protection as summer temperatures continue to trend higher in many areas. I use the "Extended Performance" given the sale price is only $5.00 more when purchasing the 5-Quart jug. I still change the oil and filter every 6,000 miles ... 2-times per year based on annual mileage.
william489 (07-13-21)
#594
Thank you.
Thank you.
ASE (07-14-21)
nzvlnr (09-19-21)
#597
#598
Dorman brand? Please don't use that and get an OEM one instead. Dorman is probably the worst aftermarket parts company and their products are no good.
The following 2 users liked this post by Romanova:
NewB2Lexus (09-21-21),
skeegs (09-20-21)
Romanova (09-21-21)
#600
Oil filter Housing
Went to do an oil change on the GX today using the proper metal filter removal tool and couldn't get the thing to budge. Last oil change was performed by the dealer under CPO agreement. After a hard struggle and many, many attempts, one of the fins on the housing snapped off. I was really putting some torque behind that pry bar, way more than i should have needed too. After the shock and panic subsided i called my local Dealership to get a new one ordered and couldn't help notice all the hits on aluminum units for the GX. Is this something to invest in since i will be doing the changes myself from here on? Other then the dealer over torqueing the housing is there a issue with the plastic OEM part?
Yes, I know I should have stopped at some point and taken to dealer to deal with. Not discussing that bit of impatience on my part.
Nor am I going to discuss how much "money do I really save by doing it myself"!
