Size Tires
I have had these tires now going on 4 days. I like the way they drive. The only thing is when i back up and turn the wheel to the left or right. It rubs slightly. It's not a big deal but i don't think the tire shop will take them back. I however love the ride myself. It feels more of a fuller ride. Almost feels like a truck and not an SUV. Here is the question that will continue this post. If you check up top i am getting new rims. http://www.elementwheels.com/proddet...prod=s1441885C
Regards
Josh
Regards
Josh
The tires are rubbing one screw/bolt just behind the rear side of the front tires (inner plastic wheel well). The only time they will rub is when the wheel is slightly turned (a little more when suspension is compressed). What you can do is use a heat gun and heat all around this one bolt and push it in. I have not done this but it looks like it would help (won’t hurt).
Koz
