Battery - questions, concerns, and/or problems
#181
AGM vs Lithium vs Traditional Battery
For the average GX user (no fridge or anything) is their any benefit to move to an AGM or Lithium instead of tossing the OEM battery for a $88 Walmart/big box store battery every 3 years?
#182
Personally I've not seen any benefit of AGM for GX. All that GX needs is the required CCA to crank up, its not a performance engine which uses battery for anything other than basic electronics which get the exact same power from a flooded battery. Just a rant: my 2 year old OEM panasonic lexus battery died and they replace with a regular oem 84 month one (same as big box stores, just a better warranty on sticker).
#183
In terms of AGM i do need a mod I assume, and again the warranty is the same just more expensive.
Lithium is something I have heard about but the battery prices quite out there.
#185
These are the main characteristics of each type that I know of, they both cost more than a regular lead acid:
AGM=ability to deplete without damaging, can accept charge faster, can mount on its side, heavy
Lithium=less weight, more capacity for same physical size, doesn't perform well in extreme cold or heat
feel free to correct me if I'm wrong, but basically stick to lead acid with the longest warranty if you don't do anything other than start the car with it
tipsytopsy (12-10-20)
#186
OEM 84 month lexus battery also can be had for $120 https://parts.lexusofkendall.com/oem...-00544mf24f630
But IMO its better to get a 800cca battery vs a 630cca (original panasonic battery is 530cca). Batteries always deplete in capacity - and GX will not start below 375cca (from what i saw when my battery died). If you've a better CCA - there is a longer depletion cycle you can enjoy.. i.e a longer battery life.
If I had to change battery today - I would just get the Interstate 24f from Costco and call it a day.
coolsaber (12-11-20)
#187
My Panasonic battery just died yesterday and I went with an AGM replacement even though it was more expensive. I’m in Canada and the car is parked outdoors all winter, not driven daily, and often used for short trips. I felt the AGM was better suited in this case but that’s just me. If I was in milder climates it probably would not be a thought.
#188
cltchmoney (12-11-20)
#189
Wow thanks for this and a great reason why this forum is so awesome. I just did some research on this and ordered a diode today. If I'm paying almost twice the price for an AGM I do want the full benefits and for it to last. The only thing I don't love about this mod is that it removes the fuse. Do you risk damaging the charging system say during a incorrect jump start as an example?
#190
#191
#193
Costco 36 months no question ask warranty is great. All my other cars have Costco Interstate batteries.
My GX has one from AAA because the previous one was from AAA and it was dead so they came and replaced it with prorate so I went with it.
#194
I just went through the same thought process. Ended up getting a Napa AGM battery, ArcLight and a battery charger just to have.
ArcLight should be here Monday. I just fully charged the battery and will install both on Monday.
Good luck.
Good luck.
