Battery - questions, concerns, and/or problems
Old 12-11-20, 02:02 PM
  #196
YGBSM352
7th Gear
YGBSM352's Avatar
I wasn't just the Airbus that had problems with Lithium batteries. Overheating occurred in a number of the newer hi tech airframes.
Old 12-11-20, 02:13 PM
  #197
cltchmoney
cltchmoney's Avatar
I ended up second guessing myself and took another look at my battery as I had no issues installing it on the tray and I have 24F AGM battery not a 27F. The charging voltage is between 13.8-14.6v while float is 13.4-13.6v. Given the alternator charges at ~14v I actually don’t think I need the alt-s diode mod now. This is a Canadian manufactured battery so I’m wondering if it is just not offered in the US. May have wasted $5.... any insight?
Old 12-12-20, 09:07 AM
  #198
coolsaber
coolsaber's Avatar
Does it have the battery mfg stamped on the actual battery? Usually its Deka, East Penn, or Johnson Controls/JC
Old 12-12-20, 10:43 AM
  #199
SlickTRD
SlickTRD's Avatar
you will need the diode - stock gx460 will absolutely not provide the proper voltage for agm batteries. the diode mod is simple, safe, effective - dont talk urself out of it.
Old 12-13-20, 07:19 AM
  #200
cltchmoney
cltchmoney's Avatar
This is a motomaster eliminator battery sold in Canada by Canadian Tire and made by Exide (also a Canadian company). Specs can be viewed here: https://www.canadiantire.ca/en/pdp/m...p.0102420.html
Yes, since I already have it in the mail it seems like there is no harm in doing it anyway... I have seen some videos measuring the charge of the GX460 alternator at a steady 14v though at idle so it made me second guess since the sticker indicates it is charging at 13.8v and above.
Old 12-14-20, 07:35 AM
  #201
Soap
Soap's Avatar
So I have had a Champion 24F AGM battery installed since April and this is the first time I have come across something like this. Let me watch this video and see what I need to do now. (Also just put an AGM in my wife's 2017 Ford Edge last week)
Old 12-14-20, 07:39 AM
  #202
SlickTRD
SlickTRD's Avatar
4runner is on very similar platform as the gx so read this - https://trail4runner.com/2019/01/30/...oster-4runner/
ford edge unsure because they might have a diff charging profile.
Old 03-03-21, 08:23 AM
  #203
BradTank
BradTank's Avatar
Default Anybody else having weird battery issues? Battery internal short, two in a row?
I had a previous post where my climate control and stereo were doing weird things. Car is still under warranty, took it in, and the day I had it scheduled, wouldn't start. They said the car battery has an internal short and that was causing all my other issues. Battery is relatively new, less than a year old. I had replaced it myself because the Lexus OEM battery that was only a few months old left me stranded in an area where there weren't any Lexus dealerships, so I had to buy one from Walmart. So I'll be on my 3rd battery in under 2 years.
My concern is, either I'm really unlucky or the car is doing something like overcharging the battery. I've never had this happen with a car before, car is daily driven. I only have a few weeks left on the warranty, any ideas?
Thanks
Old 03-03-21, 09:56 AM
  #204
Romanova
Romanova's Avatar
Sometimes batteries are junk. Had that issue with an Interstate battery on my LS430. Now I just buy them from Costco because they are cheap and the warranty is good. In AZ, much like TX, the hot climate can also do a number on them so I usually just replace them every three years anyways. YMMV.
Old 03-03-21, 11:07 AM
  #205
lawrence1
lawrence1's Avatar
For some reason Lexus batteries can be problematic ... many cases of early failures are documented on many used but relatively new cars I've looked at. I've also experienced it a few years back on Lexus cars I've owned. Nothing to worry about, they'll replace it under warranty and the battery warranty will start over.
Old 03-06-21, 11:09 PM
  #206
jsanders
jsanders's Avatar
Default AGM battery?
2016 GX battery drained completely. Car isn’t driven much. Sometimes not for weeks at a time Decided to replace battery with a Champion AGM 24 battery. Good idea? Any voltage issues? Is AGm better for infrequently driven cars?
Old 03-07-21, 07:51 AM
  #207
WRD4chano
WRD4chano's Avatar
the gx does drain the battery over time. either disconnect the terminal when not in use or trickle charge it.
as for the agm battery, you'll need a voltage booster. here are some options
Old 03-07-21, 05:30 PM
  #208
jsanders
jsanders's Avatar
Is the voltage booster really necessary?
Old 03-07-21, 07:21 PM
  #209
kode3
kode3's Avatar
Yes, or overtime an AGM battery will be destroyed. Others will say it's no big deal, and perhaps 2-3 years out of a battery is enough, but AGM's are designed for 5-10 year lives if maintained properly.
I should say I just did the GM diode mod for 8 bucks and achieved the same result as an ARC Light.
Old 03-07-21, 08:43 PM
  #210
T4Fun
T4Fun's Avatar
7 years on my original battery. dont turn on lights without engine on. many of u leave it on auto and lights are on when engine is off. drains battery.
WRD4chano (03-09-21)
Quick Reply: Battery - questions, concerns, and/or problems
