Battery - questions, concerns, and/or problems
Old 05-30-17, 12:59 PM
  #61
Acrad
Super Moderator
Acrad's Avatar
Received 3,646 Likes on 2,388 Posts
Even though I am not noticing any issues I should proactively swap out the stock Panasonic. It is right at 5 years.
Old 05-30-17, 01:30 PM
  #62
JT4
JT4's Avatar
^ You could have it load tested, but if it's 5 years old I would replace it. That's a long time on the original OEM battery, and sometimes they die without warning as I learned first hand with an Acura years ago..
Old 05-30-17, 01:54 PM
  #63
Acrad
Super Moderator
Acrad's Avatar
I'll probably keep the core and use it for one of my game cameras or solar projects. The piece of mind will go a long ways especially since AAA or others for that matter may often be far away from me in my offroad travels.
Old 06-03-17, 03:22 PM
  #64
Acrad
Super Moderator
Acrad's Avatar
I proactively swapped out stock battery today. I just went with a Duralast 35-DLG... I had intended to get a 24F-DLG since the latter was a 750 CCA rated but picked up the wrong spec sheet on way to store and ended up with a 640 CCA (35-DLG) battery. It still has a higher rating that stock Panasonic's 595 CCA rating. Not gonna sweat it. I could already tell it sounded like starter spun faster.. but we'll see. 3 year 100% replacement with final 4/5 pro-rated.
I thought I was going to have to reset at least the windows. All settings were saved and nothing apparently reset. Battery was disconnected for about 5 minutes or so before the new one got attached. Only thing I saw was nav stating a message it was "starting up.. please wait" when I powered on the first time.
The challenge on the 24F would have been the length of the positive lead. Battery is like an inch or more higher and doesn't look like really any additional slack on that wire. Oh well... I guess I don't have to worry about that challenge now.
Old 06-03-17, 03:39 PM
  #65
tecman
tecman's Avatar
I think my nav defaulted to a different location than where I live and I needed to reset it. I think it defaulted to North East and I am SE.
Old 06-03-17, 04:22 PM
  #66
Acrad
Super Moderator
Acrad's Avatar
Just checked and region stayed in place as well
Old 06-04-17, 06:15 AM
  #67
Oldmanb777
Oldmanb777's Avatar
If you have ever watched batteries being rebuilt, it sheds some light on CCA. There is a battery rebuilder here. Very interesting. They take the old batteries, take the top off them, dump all the old plates and stuff out. Wash out the old case, and put in new plates. I had wondered why under heavy loads, like winch use, the higher CCA batteries didn't last very long. So I asked them. They showed me a 24 series 1000 CCA battery (I think it was a Sears battery) and a 600 CCA series 24 battery. Same case, just more plates in the higher CCA battery. Their response was, if you want it to last, less plates means it doesn't get as hot under heavy loads, and will last longer. The additional plates in the higher CCA batteries can't stay cool enough for good longevity. So I started using that theory in my Jeep with the winch, and found it to be true.
Acrad (06-04-17)
Old 06-04-17, 09:28 AM
  #68
Acrad
Super Moderator
Acrad's Avatar
Interesting on the plates. Good info to know. I've started using some Lithium Iron Phosphate (LiFePO4) batteries in a few of my ATVs. Expensive though... I would have just gone AGM but battery trays aren't big enough for larger batteries and these things are like paperweights and far smaller in comparison. The quads have 3K WARN winches and heated grips and throttle like sleds. Supposedly a lot safer in comparison to other Li-ion ones but I guess I have to take their word on that.
http://earthxbatteries.com/our-batte...ery-technology
Old 06-17-17, 08:20 AM
  #69
Acrad
Super Moderator
Acrad's Avatar
Saw this in FSM when replacing battery.
cancruiser (08-25-22)
Old 07-03-17, 04:40 AM
  #70
texas008
texas008's Avatar
Default 2014 GX460 battery with 450 CCA
2014 GX 460 exactly 3 yr old, with 30k miles, just did a test and the battery has 450 CCA.
the battery does not give any problems, the truck starts every time fine,
wonder if its time to replace the battery?
Thanks
Old 07-03-17, 07:08 AM
  #71
ELEX470
ELEX470's Avatar
GX battery can last up to 6 years, depending on usage/mileage.
Old 07-03-17, 08:06 AM
  #72
Acrad
Super Moderator
Acrad's Avatar
It's probably fine.... I just swapped my OEM unit out at 5 years as a preventative maintenance item. Old battery still worked but I can tell it was likely impaired as cranking sounds quicker with new battery.
https://www.clublexus.com/forums/gx-...ml#post9886478
Old 08-07-17, 09:39 AM
  #73
traubgator
traubgator's Avatar
Default Certified 2013 - is battery covered?
I have a 2013 GX460 that will not start. Its clicking. My guess its the battery, but haven't had a chance to diagnose it yet.
We have a full certified lexus warranty on the truck, does the lexus warranty cover the battery?
Old 08-07-17, 03:51 PM
  #74
Dallasguy1
Dallasguy1's Avatar
All Lexus battery's have 7 years limited warranty. Check what sticker is on it.
Old 08-07-17, 05:04 PM
  #75
Craig B
Craig B's Avatar
No, it's not covered...
Quick Reply: Battery - questions, concerns, and/or problems
