Battery - questions, concerns, and/or problems
#121
I live in the Tampa area and in a Ford, and 2 Jeeps we get 2 years out of batteries before we have to replace them as well. I switched to a Northstar battery in my Jeep due to a winch.So far that battery is now 3 years old. It is a deep cycle AGM battery. I am thinking of putting on in the GX here soon
Deka Intimidator batteries are highly recommended in the overlanding and camping forums (second to Northstar), but both of those are not cheap ($250+). I found this thread on ih8mud that IDs batteries made my the same manufacturer/plant that makes the Deka Intimidator batteries. I was in Sam's club and to my surprise the Duracell AGM is made by the same manufacturer (East Penn MFG) and looks almost identical to the Deka battery just with different branding. Also ended up going with a size other than stock. It's a bit shorter but has either more CCA or a bigger reserve then the stock sized one. I need to get the spacers but I've had it like this since 9/18 and no issues at all. Highly recommend it.
Stepsride (05-31-19)
#123
https://shop.odysseybattery.com/p/sp...577205761534ef
#124
Is this one (34R-790) the current one you're running in your GX with the height adapter?
Do you know which Odyssey model is equivalent to our stock, 24F?
#125
Super Moderator
I use these LiFePO4 batteries in my quads and snowmobiles. Very..very expensive but definitely save on weight and offer compelling performance. Auto version is further up there $$$
https://earthxbatteries.com/product-category/automobile
https://earthxbatteries.com/shop/etx1600
https://earthxbatteries.com/about-us
https://earthxbatteries.com/our-batt...ery-technology
https://earthxbatteries.com/our-batt...eresting-facts
"The ETX1600 is 8.9 pounds. Max charge current rating is 160-amps. Delivers 1600 Peak Cranking Amps (PCA)."
#126
This is as close as Odyssey makes. The spacer raises the battery about an inch. It snaps in and works just like your stock battery just with the added benefits. The stock tie down works fine as well.
Acrad (06-07-19)
#127
Autozone batteries in the "Gold" version do the same thing
They last till around the full replacement time. Then they give u crap and tell you they cant replace it becase there is nothing wrong with it
They have a bad cell. I can tell what one acts like without a tester
Last time I went to Cosctco. $85 vs $150 just like an earlier poster. Already lasted longer than the Autozone Gold.
It was a little tough to change out a max $20 job. Less if I did them all the time
This is in a GM product which will go its merry way soon
#128
Just like every chain you have to pick the good ones out from the bad ones. The autozone gold in FL will last 2 years and change. I always bring it back to autozone a month before the warranty is up. Amazingly I always have a bad cell. I have a beater car that I have done this 3x with no problems
#129
Super Moderator
Disconnected battery and cleaned my connections today, installed a quick connect for the trickle charger and applied some
John00 (10-20-19)
#130
looks so clean.
they do make neg terminal covers to match the pos
you can also add a supercap if you dont want to change batteries as often, or have sluggish starts in the cold or even in the warm due to an old or weak battery.
pretty sure some GMs came with them. good ones about 150$ or so.
batteries live longest in cold and work best in hot. live longest due to slow chemical reaction, work best due to fast chemical reaction. heat speeds up reactions
supercap isnt really affected by temps, and the discharge rate is so high that the 'dead baattey' will start it right up quicker than a brand new battery.
Acrad (10-20-19)
#131
Super Moderator
Thanks! Will look for a negative cover. Need to look at the supercap. I don't have any current starting issues but sounds interesting.
#132
heres the cover i have
https://www.aliexpress.com/item/32982823865.html
tight fit and doesnt see like it would ever fall off by itself
Acrad (10-20-19)
#133
the supercaps dont hold for as long as a battery, for the gx the supercap would be a compliment to the battery. even a 'dead' battery would work, but it does need a battery. 'dead' meaning wont start the vehicle but will power say a dome light enough to see.
Acrad (10-20-19)
#134
12V DC source needed to swap out old battery?
Do I need to connect a DC source when replacing battery? I heard if I don't do that, I may lose some info inside car computer etc. I have 60k on current battery, it dropped below 12v when I was playing obd stuffs when car was off. The car starts/roars fine so far like a tractor.
#135
