New To Lexus Which One?
#46
We've never locked our electronic keys in the GX because it won't allow us to get out unless we take them with us. There may indeed be a "dead zone" where we could hide them in the vehicle, but I don't what to know where! More to the point ... why would you hide your electronic key so that neither you nor your vehicle could find it?
You may get "beeped at" and you may cause a scene at the car wash, but you won't get locked out. After a while, you just forget about it ... as long as at least one occupant has their electronic key. The GX doesn't care which or whether we have both, but you won't get far without at least one.
Regards,
SaniDel
P.S. The wiper 'stalk' is an ideal place to hang the electronic key for the car wash ... assuming you got the leather case with the black or gray cord. It dangles in front of the START button so anyone who tries to start the vehicle will 'discover' the key when they bump into it with their fingers. Don't worry about forgetting it and leaving it hanging on the stalk ... the GX will remind you when you try to lock the doors!
#47
SaniDel
As for hiding a FOB, well if you were to lose it in a mall or the beach or wherever you would have a spare and if you hid it I don't see how you wouldn't know how to find it again?
I leave my fob in the cup holder when I go to the car wash, never been an issue, starts for them every time.
#48
Sorry ... what I meant to say was that you can't leave the electronic key in the GX and lock the door ... the GX won't allow that, but it certainly can't detect if you leave the vehicle. We've done what you described as well ... leave the electronic key in the vehicle, with or without the engine running, while we run a short errand ... although that is risky behavior!
I didn't appreciate the need to keep a spare key somewhere "hidden, but discoverable". We received two electronic keys with our vehicle. Each can be separated into the mechanical and electrical 'parts' but we don't have a spare or a 'valet' key. If we lost one, we would rely on each other's until we got a replacement, but that works for us since there are two people, each with a key. For one person with two keys, it isn't quite as obvious a solution!
Regards,
SaniDel
P.S. The guys at the end of the car wash line expect to find the fob in the cup holder and sometime remove it from the stalk and move it to the cup holder ;-)
Regards,
SaniDel
#50
Regards,
SaniDel
#51
I think I know the answer to this question but I gotta ask anyway. Is there anyway the fob key could be locked in the car by accident? Just thinking if I take it to a car wash and leave the fob in the cup holder, and then someone accidentally locks it by hitting the dimple on the handle, could it lock and not be opened again? I would think it could happen, but then be unlocked easily. Can the car tell if the fob is in the vehicle or is it just a radius to the car?
However, I was able to lock the fob with the car off and the key in the back right seat somehow but only by using the passenger door panel manual lock button which was very strange since I couldn't do it from the driver's side door panel manual lock button and I couldn't open the door with the door handle sensors, I had to get my spare fob. While this is for a different car, I assume this is the same with the GX but now I am curious and will have to try it out on the GX. Either way, I think it is tough to lock yourself out of the car.
#52
I would think that if you do manage to lock the car with a fob inside (not the mechanical key way) it means the car thinks that the fob is outside and hence you should be able to unlock it by touching a door handle too.
The position of the fob is probably determined by triangulation (or similar) based on a signal strength received by car sensors located in different positions inside the car and this is probably why the owners manual mentions this theoretical possibility since the positioning can't be 100% accurate but good enough for any practical use (i.e. people not trying to trick the system).
#53
Forgot to provide an update. I tried to lock the fob in the GX even in a number of areas including the cargo area and it would not let me lock the doors any which way I tried so even if there is some chance it could happen it is highly unlikely.
TheREDOne
12-06-20 05:44 PM
