maintenance on 2011 GX 460
Old 07-26-13, 05:56 PM
Quadro
Quadro's Avatar
I plan on MS/2 after OEMs wear out too. Moreover, I called my dealer and they had no issue installing these.
Quadro is offline
Old 07-27-13, 08:57 AM
danwguys
danwguys's Avatar
I am assuming you guys are talking about Michelin LTX MS/2? i went to michelin site and it says this tires are not compatible with GX 460, did you guys put them on anyway?
danwguys is offline
Old 07-27-13, 09:05 AM
Eppieguy
Eppieguy's Avatar
Koz did, I will but haven't yet.
Eppieguy is offline
Old 07-27-13, 06:45 PM
Capirato
Capirato's Avatar
YES
~ Cap
Capirato is offline
Old 07-28-13, 07:09 AM
Quadro
Quadro's Avatar
OEMs are H-rated while MS/2 are T-rated. T-rated tire, by the way, exceeds top rated speed for GX posted on lexus.com which is 110MPH. Not sure if anyone here actually tested the speed limiter and it's true.
Quadro is offline
Old 07-28-13, 07:56 AM
Koz
Koz's Avatar
Because of liability reasons all tire manufactures will only recommend the exact same rated tire the OEM uses when new. In this case the OEM speed rating is 130 mph and the GX cannot even reach this speed (speed limiter kicks in at approx 110 mph (I've hit this limit). The LTX MS2 is perfectly fine to run on the GX!
Koz
Koz is offline
Old 07-28-13, 12:18 PM
Quadro
Quadro's Avatar
Right so MS/2 are rated faster than GX can ever go if 110mph speed limiter is obeyed.
Quadro is offline
Old 07-29-13, 05:50 AM
Koz
Koz's Avatar
No the "H" rated 130mph HP (OEM size which is why they cost more) are rated higher then the GX can go. The MS2s are "T" rated (118mph), which is perfectly fine for the GX.
BTW - I'm running the LT LTX-MS2s that are "R" rated (106 mph).
Koz
Koz is offline
Old 07-29-13, 05:57 AM
Koz
Koz's Avatar
The speed limiter kicks in at approx 115mph causing the engine to shut down and will not allow higher speeds.
Koz
Koz is offline
Old 07-29-13, 08:46 AM
Quadro
Quadro's Avatar
Koz
OK so it's just about pushing the limit for the T but not quite.
Quadro is offline
Old 07-29-13, 08:47 AM
Quadro
Quadro's Avatar
Koz
Any other differences between T and R rated ms/2?
Quadro is offline
Old 07-29-13, 10:50 AM
Koz
Koz's Avatar
What you have to know is that the speed rating is not a limit that if you reach or exceed the tire will not fail. You would have to exceed that limit for an extended period of time. So for the few seconds you may exceed that limit the tire is not going to fail. Not only that, who is actually going to ever reach these speeds in an SUV. The most important safety precaution you need to practice is keeping the tire properly inflated.
Interesting fact - Most off-road tires are only speed rated from 70 to 89 mph.
Koz
Koz is offline
Old 07-29-13, 11:06 AM
Koz
Koz's Avatar
There is a huge difference between the T and R rated tires. The "T" rated tires are "P" (Passenger) tires that are "SL" load rated (at 44psi max) that can carry approx 2271 lbs. The "R" rated tires are "LT" (light truck) tires that are "E" load rated (at 80psi max) that can carry approx 3415 lbs. The LTs are also Green X tires. They have a lower rolling resistance, for better gas mileage.
Koz
Koz is offline
Old 07-29-13, 11:23 AM
Quadro
Quadro's Avatar
I see now... It's a pity R don't come with P265/60R18 OEM size... but the H do. If one wants to keep the stock size -- any opinions on H-rated MS/2 vs stock Latitude HPs?
Quadro is offline
J295
GX - 2nd Gen (2010-2023)
04-20-18 10:25 AM
turtle2678
RX - 3rd Gen (2010-2015)
08-10-16 02:25 PM
texas008
13
02-16-15 06:38 PM
smackman
01-09-13 03:21 PM
Quick Reply: maintenance on 2011 GX 460
