how to reset maintenance message in gx460
Old 03-06-14, 08:58 AM
jaleels
jaleels's Avatar
Default Annoying Oil Maintenance Reminder
My dealer changed my oil about 5000 ago and now there is a annoying oil maintenance reminder in the multi-info display. The GX only needs to have it's oil changed every 10,000 miles and I have scheduled a reminder in the reminder vehicle section of the reminder screen. I followed the instruction in the manual to remove the oil reminder out of the multi-info display but it does not work. Does anyone know how to remove the reminder? I have a feeling that the dealer put it in the display and only they can remove it. Thanks guys.
Old 08-18-14, 04:54 PM
waiman3
waiman3's Avatar
Thanks, great forum take cares all my needs
Old 08-19-14, 08:49 AM
waiman3
waiman3's Avatar
BTW, below the only method work on the 2104 GX, other methods such holding ODO/TRIP and ignition which is in the Manual didn't reset.
Originally Posted by rockydog
Got this from the Lexus SA yesterday:
1. Start car
2. Press the ODO/TRIP button to the left of the steering wheel.
3. Go to trip "1" (there are 3 meters), then turn off the ignition
4. While holding the ODO/TRIP button, and WITHOUT PRESSING THE BRAKE, push the ignition button twice, do not release the ODO/TRIP.
5. You'll see the Oil Maintenance dialogue in the center of the instrument cluster resetting. Release the ODO/TRIP when the dialogue is finished.
6. You're Done!
Old 10-16-14, 09:46 AM
dstock
dstock's Avatar
BTW, here's how to do it:
1. Start car
2. Scroll thru the gauge cluster menu until it is a blank screen
3. Turn off car
4. Press and hold ODO/Trip button
5. Push ignition button two times to the on position (without foot on brake)
6. Keep holding ODO/trip and should see oil resetting
7. Keep holding until you see oil reset COMPLETE
Go have fun
GB2011GX (06-30-17)
Old 10-20-14, 12:58 PM
tgergen
tgergen's Avatar
Thank for posting that rockydog. I had the same question and will give it a shot.
Old 11-16-14, 10:51 AM
macker40
macker40's Avatar
Default resetting message
I have a 2014 GX 460 aND I have reset the message using the Odo/Trip..start button instruction and it works 100%
Old 12-19-14, 09:41 AM
Eppieguy
Eppieguy's Avatar
Default Oil Maintenance Required
Ok, we all know the GX has 10,000 mile oil change intervals, so why does my oil maintenance required message pop up every 5,000 miles? It's annoying.
Old 12-19-14, 11:05 AM
Craig B
Craig B's Avatar
I don't know what year your vehicle is, they changed it after the first six months of the 2010 model year to 10,000 miles.
Old 12-19-14, 11:48 AM
Eppieguy
Eppieguy's Avatar
2012, every 5k it comes on.
Old 12-19-14, 01:37 PM
Craig B
Craig B's Avatar
Strange, I would ask the dealer next time you have it in for service....
Maybe they can reprogram it.
Old 12-22-14, 08:52 AM
nsaldanh
nsaldanh's Avatar
I have a 2012 as well and the reminder comes on every 5K. I just disable it and keep driving till I need to change the oil at 10K.
Old 12-22-14, 09:07 AM
Eppieguy
Eppieguy's Avatar
I'm going to reset it myself but it's annoying, it's like they want you to come back and spend money that isn't needed. Seems like a ploy to me. I'm just wondering if there is a way to set it to come on every 10k as it is supposed to.
Old 02-07-15, 07:32 PM
jeremeydj
jeremeydj's Avatar
Default 2011 GX 460 info missing from the manual
The piece missing from the manual is that Trip A needs to be displayed on the odometer before starting the procedure.
blutopless (11-13-18)
Old 03-07-15, 09:36 PM
boyfester
boyfester's Avatar
This procedure worked on our 2014 ES350 too. Thanks!
Old 03-18-15, 09:03 AM
SilverLady
SilverLady's Avatar
By the way, you can download the manual if you register on the Lexus official site. Kind of a pain, because you have to download each section (which is poorly described in the file names), but it is there.
Quick Reply: how to reset maintenance message in gx460
