how to reset maintenance message in gx460
#32
Search button is your friend.......
#33
Got this from the Lexus SA yesterday:
1. Start car
2. Press the ODO/TRIP button to the left of the steering wheel.
3. Go to trip "1" (there are 3 meters), then turn off the ignition
4. While holding the ODO/TRIP button, and WITHOUT PRESSING THE BRAKE, push the ignition button twice, do not release the ODO/TRIP.
5. You'll see the Oil Maintenance dialogue in the center of the instrument cluster resetting. Release the ODO/TRIP when the dialogue is finished.
6. You're Done!
1. Start car
6. You're Done!
Reviving an old thread here - But thanks for the above info. The 2015 GX460 owners manual instructions to reset the maintenance required indicator are incorrect. Thanks to this forum & a quick search the procedure rockydog posted worked like a charm. Thanks
#35
How to reset oil maintenance on the dashboard
I just changed my oil 2 weeks ago and I still have this "oil maintenance required" on my dashboard. Does anyone know how to reset this? I've reset the all the maintenance on my NAV screen, but to no avail. Please help!
#36
1. Start car
6. You're Done!
6. You're Done!
Romanova (06-04-18)
#39
The foregoing was offered in jest to lighten the mood of an ancient thread and for any (like myself) who happen along long afterwards.
Btw, thanks for the info dstock!
#40
Maintenance Required message meaning?
What exactly does the Maintenance Required message mean? I have 2014. I have read the manual, several times. In a loaner, which was a newer model, it said Oil Change, so I'm leaning toward that being what is needed on mine. I just want to ensure its not something more that needs to be hooked up to a computer.
#41
#43
Yes you can,
This is for 10-13 and i think it works on 14+ too
1. Start car
3. Go to trip "A" (there are 3 meters), then turn off the ignition
6. You're Done!
1. Start car
6. You're Done!
