Vibration/Shake Issues
Old 12-16-10, 12:07 PM
  #136
Luke27617
Luke27617's Avatar
Originally Posted by Craig B
That sounds great. The 1500.00 was for the valve spring recall on my LS 460.
I hope you test drive the new vehicle before making the deal...
Good luck!
Didn't have a chance to test drive due to snow fall we are getting. I hope the new one will not have any problems. I will pick it up tomorrow as I have asked to replace tires for Michelin from another truck. Also they need to move side moldings from my old one. Driving a demo meantime and it drives substantially better then my old one.
Old 12-16-10, 12:14 PM
  #137
SaniDel
SaniDel's Avatar
Originally Posted by Luke27617
On a good note, I have worked out a deal with the GM to do a trade for identical interrior/exterior/specs 2011. Will be closing the deal tomorrow as I have asked them to move tires from other GX (didn't want Bridgestone), move the hitch (new doens't have one) and Premium model side moldings I have installed from my to the new one.
Too bad I don't have $1500 certificate some got. I think you get it if your car had a recall, or something.
Congratulations, Luke ... this is the best way to resolve the issue. Whatever is the problem with your current vehicle becomes Lexus' problem, you start over with a new vehicle ... also a 2011 model year ... and eventually someone will buy your current vehicle as a used 2010. Presumably, Lexus will have fixed the problem and if not, offered it "as is" at an attractive discount to the new owner.
Regards,
SaniDel
Old 12-16-10, 12:20 PM
  #138
Luke27617
Luke27617's Avatar
Regards,
SaniDel
Thanks! Corporate manager from HQ commited to fix the issue by sending a specialist in mid Jan. I have offered to come back and show again issues. I hope they will make it right and do not sell it with an issue. The trade-in difference was very attractive so I took the offer instantly. I just hope the new one doesn't have any problems. Maybe I have the unlucky color
Old 12-23-10, 08:02 PM
  #139
pierpark
pierpark's Avatar
I have 2010 460. The Lexus engineering department from Japan came into my dealership to tackle the vibration issue. My dealer had balanced, but when the engineering team came in, they balanced the tires/wheels in 4 ways vs. two that dealerships are equipped to do. My tires and wheels were outside of the tolerance levels for Lexus. In the end, they sent 4 tires and wheels from the engineering lab that that seemed to work just fine. I laughed (sorry) when I saw the 65 MPH thing because I could close my eyes and know I reached 65 because of the vibration! I hope they get it worked out for you because I understand your frustration. Cheers!
Old 12-23-10, 09:01 PM
  #140
Luke27617
Luke27617's Avatar
Well it is not my problem anymore as I have traded for a 2011 GX. Looks like Lexus has a wheel design problem if it takes engineers to balance wheels and all of us will have a problem next time wheels are balanced or tires replaced.
Is the truck perfectly smooth now or you still feel something from time to time?
Old 12-25-10, 06:25 AM
  #141
T4Fun
T4Fun's Avatar
i put new michelins on mine, and it seems it was vibrating at times around 60, but not now. very strange vibration pattern. In any case, toyota does not make the wheels, they get that from a part supplier, which one is the question?
Old 12-25-10, 09:37 AM
  #142
SaniDel
SaniDel's Avatar
Our 2010 GX 460 with less than 9,000 miles went in for its first annual service just before Thanksgiving. The service report indicated all tires at 8/32", the front brakes at 12/32" and the rear brakes at 11/32". I found no evidence that they rotated, balanced or aligned the wheels and tires, but I am glad if they did not!
As we are experiencing none of these problems and the brake and tire wear seems very uniform, perhaps our dealer avoided "borrowing trouble" by leaving things as they are. Time and wear will require us to rotate the wheels at the least and eventually to replace the tires, at which point we may experience these problems.
Regards,
SaniDel
Old 12-27-10, 04:53 PM
  #143
pierpark
pierpark's Avatar
I no longer have the vibration issue after the wheel and tire replacement and the balancing. The engineers that balanced the wheels used equipment that my dealer does not have so I am not looking forward to replacing the tires. I have crap Bridgestone tires on mine...these are the worst tires that I have ever driven on and am worried about replacing them because I am afraid of the vibration issue resurfacing. I agree that Lexus has issues and I have been in contact with them several times directly because of their issues. If my 470 were still on the dealer lot I would take it back in a heartbeat. I never had these issues. Also, there is a jarring vibration if someone cuts you off when you are doing 65+ MPH with radar cruise control on. This has happened twice, but the engineers were unable to replicate so no resolution there.
Old 12-28-10, 04:33 PM
  #144
Craig B
Craig B's Avatar
I switched out my wheels and had my tires mounted and balanced at dealer without any problems. I traded for a set of factory wheels that were chrome PVD plated... I will only let my dealer balance my wheels after reading all the problems people have experienced. They use a Road Force machine at my dealer to balance wheels.
Old 12-29-10, 08:40 PM
  #145
Luke27617
Luke27617's Avatar
Both dealers here do have the Road Force and couldn't get it right. It maybe something more faulty and have nothing to do with wheel balance. Before I have traded my 2010 for 2011, two lexus dealers and three different tire shops balancing didn't help.
Old 12-30-10, 08:42 AM
  #146
Craig B
Craig B's Avatar
Luke, you're lucky they traded you out of your other vehicle. Now, it's not your problem...
Old 05-18-11, 05:31 PM
  #147
Risa
Risa's Avatar
Default 2011 GX460 constant shaking
have had 2 gx470's perfect - new 2011 gx460 constantly vibrating when driving
michelin tires perfect not the tires they are saying this is the way they feel
now impossible - constantly feeling the road and all shaking
anybody else have this problem any way to fix
lexus says no don't believe they could ruin a wonderful vehicle
can someone please help miserable
Old 05-19-11, 12:27 AM
  #148
KillaIS250
KillaIS250's Avatar
You posted in the wrong section lol belongs in the GX models section, this section is for questions/issues related to navigating the site really.
Old 05-19-11, 08:08 AM
  #149
Craig B
Craig B's Avatar
I have a 2010 and I don't have this problem. Have they checked your wheels to see if they're balanced? Someone else had a bad rack and pinion that was causing this problem.
Old 05-19-11, 06:59 PM
  #150
Luke27617
Luke27617's Avatar
Describe the vibs. Specific speed, RPM, in the steering wheel, whole truck, etc....
I had the problem as well and even exchanged 2010 for 2011. Maybe will be able to provide some guidance.
Quick Reply: Vibration/Shake Issues
