Vibration/Shake Issues
Old 03-10-14, 04:13 PM
  #346
2GSKaizen
2GSKaizen's Avatar
If everything was fine, you swapped a tire, and now it's not fine, I'd def suspect that tire. It's the only thing that changed. If it was a wheel balance issue you would get the vibration at a certain speed, regardless if you were pressing the brake or not. How old is the front tire you didn't replace??? If it has substantial wear on the inner shoulder of the tire that could cause a shimmy under braking.
Old 03-10-14, 08:09 PM
  #347
MickeyS
MickeyS's Avatar
The front tire I didn't replace is only four months old, they are practically new. The rotors were resurfaced two years ago for the first time by the dealer...
Old 03-11-14, 07:38 AM
  #348
frank69m
frank69m's Avatar
Warped rotors?
Old 03-11-14, 07:44 AM
  #349
Eppieguy
Eppieguy's Avatar
Originally Posted by frank69m
Warped rotors?
Exactly what I was thinking, and with them being cut once already, It would be a good guess that the rotors are the issue.
I never cut rotors, throw them away, buy new, once you make them thinner by cutting them, they warp that much faster.
Just my .02
Old 03-11-14, 07:54 AM
  #350
MickeyS
MickeyS's Avatar
I don't think the rotors are the issue. Today I drove a little faster on the highway and the steering wheel was shaking even without pressing the brake.
Old 03-11-14, 08:47 AM
  #351
Eppieguy
Eppieguy's Avatar
Ok, then thats easy, you have a bad tire or a bad balance job.
Old 03-11-14, 11:24 AM
  #352
MickeyS
MickeyS's Avatar
Would warped rotors vibrate at a specific speed or no matter the speed you would feel the shaking?
Old 03-11-14, 11:38 AM
  #353
Eppieguy
Eppieguy's Avatar
When braking they should vibrate at any speed as long as you are applying the brakes, more so as you are slowing.
Old 03-11-14, 01:09 PM
  #354
Craig B
Craig B's Avatar
I also think you have warped brake rotors as well...
Old 03-12-14, 04:58 AM
  #355
MickeyS
MickeyS's Avatar
My brakes don't vibrate all the time, it only happens at a certain speed and now I notice the vibration at higher speeds without stepping on the brakes.
Old 03-12-14, 06:11 AM
  #356
Eppieguy
Eppieguy's Avatar
This has gone back and fourth a few times here. Bottom line is that if you're not stepping on the brakes and you're getting a vibration at different speeds you have a tire / wheel / balance issue. Take it to a tire place that has a "Road Force Balancer", have them check the new tire first, it will show you if you have an out of round tire and it's one of the best balancers out there.
Old 03-12-14, 06:28 AM
  #357
nipponbird
nipponbird's Avatar
Don't know if you're the DIY -type, but I would swap the wheel that's been worked on for one on the rear (or the spare, if the vehicle is so equiped, Well, unnecessary to say, but if you still have a vibration, you can give the wheel and tyre a lower priority in the culprit stakes.
Old 03-12-14, 07:03 AM
  #358
Quadro
Quadro's Avatar
One other thing road force balancing does is tells you the optimal way to mount all 4 tires (match balancing). If you went to a place which doesn't have RF balancing and they simply balanced that single tire separately you may get less than optimal result if the previous tires were match balanced.
Old 03-12-14, 08:20 PM
  #359
MickeyS
MickeyS's Avatar
Who has these Road Force balancers? Does the Lexus dealer have one?
Old 03-12-14, 09:39 PM
  #360
T4Fun
T4Fun's Avatar
if they overtorqued the wheel, ive read that can warp rotors, but honestly, it sounds like bad tire or balance job.
try putting spare tire on and leave new tire off and see what happens.
Quick Reply: Vibration/Shake Issues
