#Vibration / #Shake Issues
Old 04-19-17 | 07:54 AM
  #451
Craig B's Avatar
Craig B
They can tell if the tire is out of round when Road Force balancing. I would take it back to the dealer. BTW, don't go with Bridgestone
tires, they're junk in my opinion. Had them on my 2014 at delivery and had them swapped out for Michelin LTX M/S2's
Was your vehicle under any warranty/certified when you purchased it? I would let the dealer take care of the problem.
Road Force is the only way to go, I have mine balanced at the dealer.
Good luck,
Craig
Old 04-19-17 | 11:26 AM
  #452
bbqsoup's Avatar
bbqsoup
Do you usually go to the dealer to do Road Force Balancing?
I've been using America Tires to balance all my tires for previous and current cars and they have been very good.
Old 04-19-17 | 11:58 AM
  #453
Craig B's Avatar
Craig B
The dealer is the only one I know who has a Road Force machine. I always have my dealer replace my tires as well. I don't trust some of the tire shops, they've damaged my wheels in the past. If you have a tire shop you trust and they have a Road Force machine, go with them. If the vehicle is under any kind of warranty, I would take it back where you purchased it from.
Old 04-19-17 | 01:46 PM
  #454
BradTank's Avatar
BradTank
I've never had my tires "road force balanced" in my life and have never had a problem with vibrations at freeway speeds without it.
Not saying there is zero value to it, but my guess is you have a tire shop that is not properly balancing your existing tires is why you are having issues. I have returned to a tire shop after they had just balanced my tires because I was having vibration issues and the next tech admitted the previous one didn't do it properly.
I have also had tires that internally had an issue that was causing a vibration problem that was resolved when it was replace. I believe it was an internal steel belt separating.
If the only way you can go down the road without vibrations is with a road force balance, I think you are simply masking the issue with a bandaid and not addressing the underlying problem.
Sad to say, but not everyone that works for a tire shop is a trained, valued employee that takes pride in their work.
Old 04-19-17 | 03:23 PM
  #455
tecman's Avatar
tecman
Sorry to get off topic. Craig B, you ordered a 2018 LC 500 Performance Package (in your signature) ...Nice, I love that car. Keeping the GX? Congrats
Old 04-19-17 | 05:23 PM
  #456
Craig B's Avatar
Craig B
Thanks, keeping the GX for sure, might be selling my LS 460. It was built March 31st and should be at the dealer on or before May 22nd.
Liquid Platinum/Black.
Old 04-23-17 | 01:36 PM
  #457
StrannikMD's Avatar
StrannikMD
Hunter Road Force balancers locator:
http://www.hunter.com/gsp9700
Old 04-23-17 | 03:42 PM
  #458
Acrad's Avatar
Acrad
Super Moderator
Are we talking "Road Force Touch" or "Road Force Elite"?
Old 04-24-17 | 09:55 AM
  #459
Nickk6's Avatar
Nickk6
If you need road force balancing on a GX460, something is seriously wrong with the rim or tire. I still own my hunter tire changing equipment from my days of owning a tire store and I would never waste my time road force balancing a wheel on an SUV or truck. The only time I've seen it be a significant help, was when something was seriously out of round and even then, like someone said, it was just a band aid. And just FYI, a road force balance includes a high speed balance, the force just tells the operator where to place the tire on the rim. Once the tire is located to the rim, a high speed balance is done.
Old 04-30-17 | 03:45 PM
  #460
caesosa's Avatar
caesosa
Default Vibration at 68mph
Two weeks ago I posted about having tires road force balanced because I was getting a vibration at a higher speeds than 60mph. My first shot to solve it was to have the tires road force balanced. The guys at the tireshop they looked very good after I had them balanced so now I'm puzzled.
the vibration starts at 68mph and is consistent all the way to 80mph.
Now im thinking it could be a component in the car, I have the air ride (13' where only the rear rises and lowers) and it happens in all settings (comfort, sport or normal).
do you think it could be a drive shaft? What kind of movement would I look for when I'm moving it? On an old Land Rover just a little bit 2mm of movement caused a huge vibration but that was at all speeds.
All insight welcome. thanks
Old 04-30-17 | 03:57 PM
  #461
Acrad's Avatar
Acrad
Super Moderator
Might want to look through this thread...
https://www.clublexus.com/forums/gx-...gh-speeds.html
Might be your rotors.... I think there is a TSB as well related to steering rack but that only affected up the '12s IIRC
Old 05-01-17 | 08:26 AM
  #462
caesosa's Avatar
caesosa
Mine is a 13' so i don't know if that would be applicable. Brake's "should" be ok - no vibration there and they were recently changed.
Old 05-01-17 | 04:51 PM
  #463
tecman's Avatar
tecman
Rotors too? No one ever mentioned this to me during my years of frustration and it was the fix. I started getting some vibration since and went to Mr Tire/Goodyear for an oil change and I told them to rotate and balance. They informed me that a front wheel had a slight warp in it and it was moved to the rear so I probably wouldn't notice it. I did bump a curb pretty hard and I think my 2 piece wheels maybe more vulnerable to warp with doing this. It rides worse than before the rotation and balance now I am back to where I was before the rotor change.
I suspect a bad balance job this time as it is seat and stearing wheel vibrations. So frustrating
Old 05-01-17 | 06:09 PM
  #464
Acrad's Avatar
Acrad
Super Moderator
Do you know when the last time all the zerks were greased in the drivetrain? I thought I remember some posts on the 4Runner forums about driveshaft vibration related inadequately lubricated grease points.
Old 05-01-17 | 06:35 PM
  #465
caesosa's Avatar
caesosa
I don't. I can probably grease those myself and check for movement on the drive shaft. On the brakes there is no vibration at all when I break so I figure I can rule that out. All in all it feels very sensitive to minor nuances.
