#Vibration / #Shake Issues
#587
Out of town with my Tundra. Will take a video when I get back home and in the company of the wife’s GX.
#588
The video seems inconclusive. It doesn’t pick up the vibration. You can see the subtle swing in the tachometer though. It vibrates in drive and reverse at idle.
#589
Do you happen to have an OBD setup to see what the idle RPM is while in gear?
IIRC think mine hovers in the 550-600 range while in drive at idle.
I haven't really paid attention to differences with AC on or RPM for that matter recently.
I will note more exact numbers this next week.
#590
Craigyyy (04-22-19)
#596
#597
I have been dealing with this issue on my '10 premium. 102k miles. The whole car shakes from ~60-75mph or so. I would not say it is dramatic but it is annoying and I can't stop thinking about it while driving on the highway, something I do a lot. I had to point it out to my wife and the toyota dealer "can't reproduce the issue". Nearest Lexus dealer is 2hrs away. Have balanced tires 3x, no change. Tire pressures are all at 32psi. Tires (Michelin defender lt) have good tread, I would guess at least another 15k before the wear indicators so I am hesitant to replace those.. No leaking from the shocks. Alignment seems okay but have not had it checked. Any other ideas? I have not greased the driveshaft in a while, could that be it?
#598
It could be out of round tires, you can increase the PSI a bit and see if it helps. Hope it's not CV joints or bearings (which could also have some humming).
#599
FWIW I first started noticing the issue not long after transmission/diffs/transfer case were flushed @ the Toyota dealer. I don't really see how any of that work going awry could cause this issue. It seems more wheel/tire/alignment/suspension related.
#600
2011, 5th set of tires!!
I'm still dealing with this problem as well. I will say Defender tires are the worst in my tire experience. There are only 3 Lexus recommends and Michelin Latitude are one of them. My GX has 127K miles now and has has tires balances, rotated and all the shaking looked at more times than I can count! Its pretty frustrating as well. I can relate to the others saying they think about it a lot...I really would like to keep my vehicle longer as its in fantastic shape other wise and always serviced at the dealer, except tires. They blame my issues on getting my tires elsewhere. I even had them balance my last set. They claimed they were unable to balance them and that they were defective (Defenders) so I am now just recently replaced w Latitudes. I haven't driven on the freeway just yet but can assume I am still shaking, just less.
