Vibration/Shake Issues
Old 07-01-19, 07:06 AM
  #601
TimeFlies
TimeFlies's Avatar
Early on when I purchased my 2010 GX460 (in 2012), I found a similar thread/solution for the 4 Runner. It requires tightening the steering rack (there is a more detailed/technical description, but it's been so long that I've lost the description). The downside of this is that the steering is tight and tries to center itself with more force than usual. This requires steering input when driving on the slope side of a crowned highway. It was annoying for a long time, but I got used to it.
I also make sure to only purchase tires and have them installed, rotated, wheels aligned, and tires road-forced balanced at my dealer. Further, my service manager understands to only install tires and road-force balance as close to "perfect" as possible - the Lexus tolerances leave too much leeway.
I now have 140k+ miles on my GX it drives very well and I keep it looking like new. Love not having a car payment!
Originally Posted by texaskathy
I'm still dealing with this problem as well. I will say Defender tires are the worst in my tire experience. There are only 3 Lexus recommends and Michelin Latitude are one of them. My GX has 127K miles now and has has tires balances, rotated and all the shaking looked at more times than I can count! Its pretty frustrating as well. I can relate to the others saying they think about it a lot...I really would like to keep my vehicle longer as its in fantastic shape other wise and always serviced at the dealer, except tires. They blame my issues on getting my tires elsewhere. I even had them balance my last set. They claimed they were unable to balance them and that they were defective (Defenders) so I am now just recently replaced w Latitudes. I haven't driven on the freeway just yet but can assume I am still shaking, just less.
Old 07-01-19, 02:35 PM
  #602
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
TimeFlies: You must have had the pre-load spring TSB performed.
https://www.clublexus.com/forums/gx-...l#post10314468
Old 07-08-19, 09:57 AM
  #603
TimeFlies
TimeFlies's Avatar
Yes. That's it!
Old 07-15-19, 07:41 AM
  #604
texaskathy
9th Gear
texaskathy's Avatar
Originally Posted by TimeFlies
Yes. That's it!
Has anyone been able to have this service done, Steering Rack Preload Spring, outside of warranty? I have been dealing with this FOREVER and first time seeing this service bulletin! If not, how much was it?
THanks!
Old 07-15-19, 05:10 PM
  #605
Acrad
Super Moderator
Acrad's Avatar
I think the part is less than $3 IIRC, a couple of $3 hose clamps and TSB states 4.2 hours of labor. I believe my local Lexus dealer charges $160/hour IIRC
THanks!
Old 07-24-19, 10:49 AM
  #606
Kriss2018
Kriss2018's Avatar
Default 2018 GX 460 2nd gen Seat vibration in park slight but annoying
I have 2018 GX 460 with 16k, it is my third one. I find that when in park I feel a slight vibration in the seat, the passenger can feel it also. Hot or cold does not matter. or if the the ac is on or off. The tach is steady at 1200 rpm. Help!! I brought it to Lexus no codes come up. I was hoping it was spark plug, coil or throttle bottle though they said code would come up!
Old 07-24-19, 11:03 AM
  #607
bbqsoup
bbqsoup's Avatar
Whenever I have the rear cup holder down, it rattles like crazy. Tuck it it and it helps alot but I do see the passenger side rear sear shakes more than than the driver side. I'll try the tower TSB lol.
Old 07-29-19, 12:51 PM
  #608
Vikesfan
Vikesfan's Avatar
Yeah, I had the same problem in my 2010, vibration in the steering wheel and seat and the steering wheel was slightly off-center. I took it into the dealer, had the wheels balanced and an alignment and it much, much better. Wasn't cheap, but happy I did it.
Kriss2018 (07-29-19)
Old 07-31-19, 09:22 AM
  #609
ROSCOGX470
ROSCOGX470's Avatar
There is a TSB for this, it’s a modification inside the rear of the seat. I’ll try to paste the link to it. I still have it but it don’t really bother me.
https://m.autoserviceprofessional.co...us-seat-rattle
Old 08-07-19, 11:18 AM
  #610
Kriss2018
Kriss2018's Avatar
Angry Vibration in seat while in park GX 460 2018
I have an annoying vibration that you can feel in the driver & passenger seats when you start the car and idle (tach steady, does not matter if AC is on or off. It is a 2018 Lexus GX 460 with 16k miles on it. It is my 4th one and never had this issue. The dealer says it is summer gas, which I only put premium-grade gas highest octane. No codes came up and they added a gas additive. They said to drive it to put a few more tanks of gas in, drive it on the highway and really get on it. And it will work itself out. Does this sound right? Anyone else experience this? Help! Hopeless in MASS!
Old 08-07-19, 12:59 PM
  #611
M7lexus
M7lexus's Avatar
I have the same issue with a 2010, I did not have these problem last summer, now you got my curiosity on why we have similar issues.
Kriss2018 (08-07-19)
Old 08-08-19, 07:22 AM
  #612
GoHuskers
GoHuskers's Avatar
When it vibrates, what is the RPM? cold start or operating temps?
Kriss2018 (08-08-19)
Old 08-08-19, 08:05 AM
  #613
Kriss2018
Kriss2018's Avatar
When cold first started it is 1100 and then it warms up and went to 8 then waited another minute it bounced a little upto 9 then to 8, I put in park it dropped to 8, then dropped to 7. Can tell at times engine does not run smooth, but only for a brief second. Since it has been out of service which was Tuesday, it is running worse.
Old 08-08-19, 08:27 PM
  #614
GoHuskers
GoHuskers's Avatar
At 700 RPM the engine should be very smooth. Mine used to dip to around 500 rpm then it shakes and vibrates. I used some piston/cylinders cleaner plus Shell gas and it hasn't done that for the last 10k+ miles. Also, take it up to 3000-4000 rpm once in awhile.
Kriss2018 (08-09-19)
Old 08-09-19, 03:38 AM
  #615
Kriss2018
Kriss2018's Avatar
Did you find it immediately ran smoother? The dealer did some type of injector cleaner but running worst than before. How long should I keep at 3-4000? I always use premium. Do you have a GX 460?
Quick Reply: Vibration/Shake Issues
