Vibration/Shake Issues
#691
Yes it is. I took it in today to a local Lexus dealer and they completed a diagnostics procedure. They claim that there is nothing wrong with the vehicle. I don't know what to do at this point, I'm starting to second guess myself about the severity of the vibration. Maybe I'm just sensitive? Could it just be a resonant frequency that comes into the cabin at specific rpms?
Vibrations, electrical gremlins are really down to personal sensitivity. Unless its staring them in the face or ear its a trek to say the least.
#692
For them its just a typical "sensitive" customer. they will say its within specs or we can't find the problem.
#693
After that it really depends on a lot of things. If the service writer is good at his or her job then you will get those results. If the service rep does not care or has been instructed from the top to move as many work orders as possible and their area is full of customers who dont know better then yea your going to see minimal effort.
#694
Thanks for all the advice! I'm going to make a call to Lexus corporate tomorrow to see if they can send out an engineer in August to take a look. I'm leaving a long paper trail of "customer concern can not be replicated at this time" and that creates a lot of bias from the service writers the second I drive in...
Is there an easy way to check the engine/trans mounts? I tried locating them the other day but the engine bay is so cramped and it is difficult to lean over the radiator support to take a look.
#695
have you (or the dealer) checked the torque on your driveshaft bolts? this is a regular maintenance item to check per the manual
#696
easiest to look for/ at the mounts from underneath with all the skids removed... they can be seen from the top with all the plastic removed but not as well...
#697
Have you tried going onto the pre-owned lot for a test drive?
#698
Michelin Defender LTX are pain in the ***. I installed them recently and initially they were balanced very well, but i powder coated my wheels last week and the shop that did it didnt balance them well enough. 65mph+ i feel vibrations, went to a two different shops after and they still can't do a good job, i feel it on the highway.
In terms of being a smooth ride, my 2015 is rock hard compared to my friend's 2020 GX. I had it for a day while my GX was at the shop and it felt so much better. I changed my LT and LF oils last week, it feels much better, smoother but 2020 is heaven for your butt in terms of comfort and a smooth ride.
#701
After paying closer attention, it seems that I may have narrowed down the issue. In park (w/ AC or w/o) I feel a shake in the engine between about 1200-1500 rpms. If I watch the tachometer while applying the gas (driving), the feedback from the engine is felt most in this range. I scanned the car and there are no codes and no misfires. Dealer said they checked a 2019 and 2020 on the lot and claims that "that's just how they are". Can someone confirm this? I've opened a case with Lexus corporate since no one is taking me seriously and keeps giving me the run-around...
if u find out issue i would like to know. i have same vibration and have just dealt with it on my michelein defenders.
very annoying. rock solid suv except for shaking.
my passenger seat shakes. does yours?
#702
I just went out to the car to move it. Yes, my passenger seat wobbles at the specific rpm range of 1300-1500 in PARK.
#703
my seat only wobbles on highway at certain speeds. its annoying. yesterday i noted when it was very hot, not a vibration at all. very smooth.
i am certain its due to the tires. tires were softer at higher temps in 90s and no vibration.
#704
I've got a '10 with bad vibes at 55+ mph, mostly felt in the steering wheel, even though when I look over at the empty passenger seat I see that jiggling back and forth too. I read through the 44 pages of the other vibrations thread -a few times- and was hoping for a clearer picture if this TSB actually fixed things for folks that did it? Reason being, the closest Lexus dealership is 4 hours from me, and they quoted me labor alone $600-700, so it would be a pretty big commitment for me to go for it. I asked them if they had done many of these, and the service guy said no, not many at all. Which makes me wonder if this is actually a fix...
I purchased the vehicle, tires on it were crap, so I had new Goodyear Ultraterrains put on. Had bad vibes, felt like things were out of balance. Had a post purchase inspection scheduled at my mechanic, he noticed vibes but said everything looked good, suggested bad balancing of tires as well.
Lexusdrivers shows both wheel bearings being replaced within the last 10K miles.
Had tires balanced threemore times. The last time they replaced a tire. Vibes didn't go away. Took it back to mechanic to look through again more closely. he checked ujoints, driveshafts, bushings, ball joints, suspension and brakes, said everything looks good, nothing that would cause vibes looked bad.
Took it back to discount, asked them to swap some smooth 4ply highway Michelins on, for experiments sake. I still have the vibes.
At this point, I'm tempted to swap out rotors, they're original and have 132K miles on them. Mechanic says no way warped rotors can cause vibes outside of braking. While I would typically agree with him, I've read here and elsewhere that somehow replacing them magically does the trick. I would go oem rotors if I do. I'm just tired of throwing time and money at this with no solutions!
I also have not gotten an alignment, although one was done within 6 or 7K miles ago.
I had a lifted 01 Cherokee on 35's before the GX and it rode smoother than this. I feel like my bar is pretty low...
#705
Just read thru the TSB; quite an involved procedure...
Our 13 with 99k has slight shakes, but nothing where I am going to drop this amount of time and money into MAYBE solving the problem.
Wish I could definitively say, “it works do it!” but I cannot.
Keep us posted of any developments.
