Advice on new GX
Advice on new GX
I just bought a loaded up 2013 Premium yesterday. Still in brain shock from trying to figure out how to use everything. Just wondering if there are any little tips or tricks that you veteran GX guys would suggest. Traded in and from a 2007 Sequoia. Thanks in advance.
Jim in WV
Jim in WV
Tip, sit in your driveway with the truck running for an hour or more if necessary and play with every option while referring to the Manuel when necessary. Trick, after making the adjustments drive it for several days to see if you like the adjustments and repeat if necessary.
