View Poll Results: Does your GX460 Lean?
Yes: Low on the passenger side
106
57.61%
Yes: Low on the driver side
19
10.33%
No, I've measured on a flat grade and it's even
59
32.07%
Voters: 184. You may not vote on this poll
KDSS Lean
#257
Owned a 2010 GX with zero lean issues. My 2014 leans to the right...sometimes. I went in and had the TSB spacer fix and it did absolutely zero difference. There’s a video on how to reset it which I admittedly haven’t tried since I bought a Dobinsons lift with their version of how to address the issue with a slightly taller coil.
#259
#260
#262
I guess I always thought the TSB fix for this was replacement of the front right coil spring but this TSB states the left front one is replaced
https://www.clublexus.com/forums/gx-...l#post10379265
https://www.clublexus.com/forums/att...41-14-rev1.pdf
#264
I agree, I have a sight lean and there is no effect to driving/feel. Purely aesthetic and sometimes it does go away (for weeks/ months) and the there are times I can’t unsee it.... you’ll be fine if it’s the only compromise.
i will try the timbren
#267
Not sure if you were making a general statement or referring to my post. This dealer did not do anything with the suspension. They performed your typical 5k mile service including oil, tire rotation, fluid checks, and whatever else needed for state inspection. I just find it interesting that it didn’t lean when it was in service- possibly parked on uneven pavement when I was there looking at it. This is inline with the numerous threads I’ve scoured over. With that said I do agree with you using spacer or installing shorter spring at left front to correct the issue is a temporary fix.
#268
Acrad (02-18-19)
#270
Fixing the lean issue?
Hi, all, after getting my 2018 gx460, I found out I am also lucky enough to have a unit that leans to the passenger side. I researched a lot and did try to adjust the KDSS, however, the KDSS control on GX460 is very different from the prado 200 and there doesn't seem to be any valve I can turn. So I am thinking of putting struct spacer or spring spacer, has anyone had experience on this? does KDSS makes this spacer placement more difficult? Thanks for any feedback.
