OEM Hitch / Tow Package
#166
Hello
I have 14 that is supposed to have tow package has tow plugs but no hitch. All my searches either come up with the $99.00 4 bolt attachment or the $300.00+ Lexus frame mount. I have found what I want but it is for the 4runner.
Will the 4runner receiver frame mount fit, do I have to remove anything from the vehicle to make it fit or is it bolt and tow?
thanks
My GX is the 14 without air ride.
thanks
#167
Hello
thanks
thanks
Randy B
#170
#171
Your local Toyota dealer can get you the hitch for about half the price Lexus will sell it to you for. We pull a 26’ Pathfinder with it all the time. This is the heavier hitch system...not the Ebay crap
#172
#173
however, if you want to tow with your 6x10 trailer then you should have the Lexus hitch which is rated at 6500 lbs.
#174
When I search 14 4Runner I have tons to choose from I think I saw 10,000.00 which is way more than I will ever tow.
thanks
#176
Just purchased a 19 GX460 Luxury, Starfire Pearl & Ecru Leather. It replaces our 04 GX470. Just curious; the 04 GX has the tow hitch, but the new GX doesn't. Does the one on the old vehicle fit this 2nd gen GX460?
#177
#179
For 2nd gen GX, the tow hitch is dealer installed accessory.
#180
At any rate, installing a hitch is quite easy for any DIY'er. If you have a few wrenches and don't mind laying under the rear of your vehicle, you can easily save a few hundred dollars installing the hitch yourself.
